Power Steering Removal
05-12-2024, 12:17 AM
I have pulled my power steering pump and reservoir out of my AE101. Just checking is the car still safe to drive ? I have just plugged the 2 hard line pipes but, read that the rack can seize if fluid runs low ? I had to pull the air con out so didn’t bother replacing the belt for the power steering. New ecu this week so just removed for space for now but would be happy making it permanent if I can safely ?
Thanks
05-12-2024, 12:46 PM
Remove the plugs and just loop a line from one side to the other. This will allow the fluid to transfer from side to side. The other option is to completely dis-assemble the rack and remove the inner piston seal.
05-19-2024, 06:48 PM (This post was last modified: 05-21-2024 06:32 PM by 20valver.)
Perfect thank you
  Kouki door card removal - help :) ondafly 4 1,583 11-02-2026 06:05 PM
  idler pulley for 4AGE with power steering/aircon ondafly 4 1,269 07-06-2026 11:11 PM
Last Post: ondafly
  4AGE cylinder head plug removal Ivan141 5 5,945 09-30-2023 09:47 PM
  Sill removal totta Crolla 3 4,595 09-14-2022 06:30 PM
Last Post: totta Crolla
  Power steering clunk Jezza_hr 12 21,104 09-24-2021 01:42 PM
Last Post: pack
