Power Steering Removal
05-12-2024, 12:17 AM
I have pulled my power steering pump and reservoir out of my AE101. Just checking is the car still safe to drive ? I have just plugged the 2 hard line pipes but, read that the rack can seize if fluid runs low ? I had to pull the air con out so didn’t bother replacing the belt for the power steering. New ecu this week so just removed for space for now but would be happy making it permanent if I can safely ?
Thanks |
05-12-2024, 12:46 PM
Remove the plugs and just loop a line from one side to the other. This will allow the fluid to transfer from side to side. The other option is to completely dis-assemble the rack and remove the inner piston seal.
05-19-2024, 06:48 PM
(This post was last modified: 05-21-2024 06:32 PM by 20valver.)
Perfect thank you
| idler pulley for 4AGE with power steering/aircon | ondafly | 4 | 991 |
07-06-2026 11:11 PM Last Post: ondafly |
| Kouki door card removal - help :) | ondafly | 2 | 1,134 |
03-08-2026 11:51 AM Last Post: ondafly |
| 4AGE cylinder head plug removal | Ivan141 | 5 | 5,718 |
| Sill removal | totta Crolla | 3 | 4,398 |
09-14-2022 06:30 PM Last Post: totta Crolla |
| Power steering clunk | Jezza_hr | 12 | 20,534 |
