Plug ID
02-13-2019, 12:02 AM
Plug ID
Finally got down to my cold start issue and it was the plug on the coolant temp sensor so I’m on the lookout for one although I think I have a spare. But incase I don’t, can anyone help me ID this plug or have a part number for one? Links to my flicker below for pics.
https://flic.kr/p/SzSafd https://flic.kr/p/SzSaoj TIA |
02-13-2019, 09:26 AM
(This post was last modified: 02-13-2019 09:54 AM by Ivan141.)
Plug ID
Looks a lot like an AMP Junior Power Timer (or mini timer) connector..
Only it isnt exactly.. the little guide pin is off center.. that's different to the run of the mill JPT connectors. Probably a specifically keyed JPT connector, little chance you'll find one new. FABRICA MI DIEM, PVNC! |
02-13-2019, 08:40 PM
Plug ID
TE 282681-1
I know it's not exactly the same, but it's probably your best bet (and it have the correct offset) The other option is filing the keying on the sensor and using a common junior timer connector like TE 826008-5 or TE 826008-2 if you want to keep the green color. |
02-13-2019, 11:08 PM
Plug ID
Thanks for the responses. Will look into these.
02-14-2019, 01:36 PM
Plug ID
Could you possibly just replace the spades inside the plug? Not sure if these can be taken apart
Sent from my MHA-L29 using Tapatalk AE86 ex-daily |
02-14-2019, 08:19 PM
Plug ID
(02-14-2019 01:36 PM)Bean Wrote: Could you possibly just replace the spades inside the plug? Not sure if these can be taken apart The plug has been taken apart in the pics. Issue is, after 33 years, it has melted and distorted out of shape meaning the spades no longer hold them selfs in place. |
02-17-2019, 10:07 PM
Plug ID
Well its fixed!
I did have an old engine loom and this had a plug on it. This loom was bought brand new from toyota about 30 years ago and used for spares for the rally car I got so it was in mint condition. I was amazed at how great the plug is meant to be!! First time in 2 years the car has started properly so I'm happy! |
Ignition switch plug and wires | Blaze0010 | 3 | 1,114 |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,991 |
16v distributor hole plug | harkes | 8 | 10,358 |
Anyone know what this plug does? | Super86 | 3 | 6,974 |
08-01-2016 03:57 PM Last Post: Nakilad |
4AGE 16v RWD Bigport Diagnostics Plug? | Rascal21 | 2 | 8,379 |
11-15-2014 09:31 PM Last Post: Bean |
