Oil temperature !?
07-14-2007, 09:30 PM
Oil temperature !?
You guys with Oil temp. indicator, what's you oil temp and in what conditions ?
What's the max temp. you had ? I've just installed oil temp. indicator, and it says little to low temp (or is it just me). After 5 min idling and 10km driving normaly it says only 60 degrees celsius. Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
07-14-2007, 11:03 PM
Oil temperature !?
seems too low.
Where did you locate it? ![]() Cump´s Filipe Oliveira |
07-15-2007, 01:17 PM
Oil temperature !?
115°C at peak of my local togue
![]() depending on outside temperatures my oil takes about 7-12min to get over 70°C (drive to work, less then 10km city drive) - can't tell about idling as my start-up idle is stupidly high but can't be arsed to fix it, as it doesn't do any harm (mechanicly) PS: sensor located at the filter wich is relocated for easy access AE86 ex-daily |
07-15-2007, 02:50 PM
Oil temperature !?
Lipinhu Wrote:seems too low. In Oil pan, on the Oil drain screw (it was made new to hold the sensor). The electric fan (for water cooler) switched on at oil temp. of 75-80 degrees.. Tnx guys.. It might be because of location of sensor, but it isn't way too low..
07-15-2007, 11:54 PM
Oil temperature !?
In my Hachi, summer, city - easy driving - about 90 - 95
winter, same comdition - 80 - 85 Uphil, a bit faster ( Mt Sljeme ) summer, 100 Track, when pushing to much, max 120 after 3 - 4 fast laps. 1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
07-20-2007, 12:13 AM
Oil temperature !?
when i was going I had around 230 farhenheit (didn't calculate back)
But I am running 5w 40 oil for circuit racing. (same goes in skylines etc) So don't know if thats good to measure. Temp depends on the outside (temp) and on the type of oil. And how you drive. When my engine is warm I don't go lower than 4k
| Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 12,123 |
12-06-2017 06:48 PM Last Post: Bean |
| trans oil, lsd oil change | Apolan | 9 | 22,636 |
| Wheel Bearing Temperature | Super86 | 5 | 9,831 |
09-29-2014 12:26 AM Last Post: jondee86 |
| Oil cooler -> low oil pressure | Jan Pedersen | 24 | 41,237 |
| 4AGE crankcase gas and oil pressure too high, sprinking oil | demogun | 5 | 11,151 |
![AEU86 AE86 - Oil temperature !? [Image: AEU86 AE86 - Oil temperature !?]](http://lipinhu.no.sapo.pt/sbanner.jpg)
