Oil temperature !?
07-14-2007, 09:30 PM
Oil temperature !?
You guys with Oil temp. indicator, what's you oil temp and in what conditions ?
What's the max temp. you had ?
I've just installed oil temp. indicator, and it says little to low temp (or is it just me). After 5 min idling and 10km driving normaly it says only 60 degrees celsius.
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
07-14-2007, 11:03 PM
Oil temperature !?
seems too low.
Where did you locate it?
[Image: AEU86 AE86 - Oil temperature !?]
Cump´s
Filipe Oliveira
07-15-2007, 01:17 PM
Oil temperature !?
115°C at peak of my local togue Smile
depending on outside temperatures my oil takes about 7-12min to get over 70°C (drive to work, less then 10km city drive) - can't tell about idling as my start-up idle is stupidly high but can't be arsed to fix it, as it doesn't do any harm (mechanicly)
PS: sensor located at the filter wich is relocated for easy access
07-15-2007, 02:50 PM
Oil temperature !?
Lipinhu Wrote:seems too low.
In Oil pan, on the Oil drain screw (it was made new to hold the sensor).
The electric fan (for water cooler) switched on at oil temp. of 75-80 degrees..
Tnx guys..
It might be because of location of sensor, but it isn't way too low.. Smile
07-15-2007, 11:54 PM
Oil temperature !?
In my Hachi, summer, city - easy driving - about 90 - 95
winter, same comdition - 80 - 85
Uphil, a bit faster ( Mt Sljeme ) summer, 100
Track, when pushing to much, max 120 after 3 - 4 fast laps.
1984 AE 86 Levin hatchback
1989 AE 92 GTi
2004 Kawasaki KLE 500
07-20-2007, 12:13 AM
Oil temperature !?
when i was going I had around 230 farhenheit (didn't calculate back)
But I am running 5w 40 oil for circuit racing. (same goes in skylines etc) So don't know if thats good to measure.
Temp depends on the outside (temp) and on the type of oil. And how you drive. When my engine is warm I don't go lower than 4k Smile
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 12,158 12-06-2017 06:48 PM
  trans oil, lsd oil change Apolan 9 22,641 10-01-2014 03:57 PM
  Wheel Bearing Temperature Super86 5 9,860 09-29-2014 12:26 AM
Last Post: jondee86
  Oil cooler -> low oil pressure Jan Pedersen 24 41,293 06-06-2013 07:36 PM
Last Post: Deuce Cam
  4AGE crankcase gas and oil pressure too high, sprinking oil demogun 5 11,171 10-01-2011 09:47 AM
Last Post: demogun
