OST-070: 7AGE for an N2 Levin
11-24-2020, 08:39 PM
Post: #31
TRD make a 0.4mm (compressed) one in case you ever need a thinner one Wink
11-28-2020, 11:47 PM (This post was last modified: 11-28-2020 11:49 PM by oldeskewltoy.)
Post: #32
(11-24-2020 08:39 PM)Bean Wrote:  TRD make a 0.4mm (compressed) one in case you ever need a thinner one Wink
Not doubting you... but I just did a search on TRD Japan... and I can't find ANY 4AG parts listed.........
This is an archive.... https://www.trdparts.jp/parts/archive/pa...a-g16.html
Dan -
11-29-2020, 04:39 AM
Post: #33
TRD don't make anything anymore for the 4AG...
11-29-2020, 10:14 AM
Post: #34
yeah my brain let me down - it's 0.5 P/N:11115-AE824
I bought mine 10 years ago through perfectrun, was still in stock then
now sitting on my shelf in the workshop back in Switzerland
12-22-2020, 08:00 PM
Post: #35
Time to get the belt on and set cam timing.
But first we have a small problem to deal with... instead of a 116 tooth timing belt, I ended up with a belt with 119 teeth....
[Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]
....someone put the wrong belt, into the right box
so once I got that settled, setting cam timing can begin.... it begins with KNOWING TDC. I use a piston stop, and determine exact TDC. Once TDC is determined, I move on to the cam card.
I take the cam centerlines and mark them on my timing wheel
and then adjust each camshaft so the cams centerline lines up with the respective marks on the timing wheel
Note: finding the centerline of the cam is kind of like finding TDC on the crankshaft, to determine the exact centerline I use a few degrees on other side of the lobes peak to determine the actual center.
Now that the cams are set according to the cam card, the timing cover, and trigger kit gets fitted.
more to come.... Hurray!
Dan -
12-22-2020, 10:46 PM
Post: #36
Not sure exactly why but I just love your tarp background pictures. They look a big step up in quality - well done.
The close up one of the cam wheels could be straight from a commercial.
Maybe it's just the bokeh effect but whatever it is keep doing it Big Grin
12-22-2020, 11:15 PM
Post: #37
I hope you dind't have to count all teeth of the cambelt to figure out it was the wrong one. Huh
12-28-2020, 05:27 PM
Post: #38
(12-22-2020 10:46 PM)Bean Wrote:  Not sure exactly why but I just love your tarp background pictures. They look a big step up in quality - well done.
Thumbs up!
(12-22-2020 11:15 PM)banpei Wrote:  I hope you dind't have to count all teeth of the cambelt to figure out it was the wrong one. Huh
I did.... no other way.
and now fitting the TecArt's ITB kit........
On top is the vacuum collector, and the fuel rail is under - yep, the injectors spray up.
Dan -
12-28-2020, 10:59 PM
Post: #39
That's painful. Blush
01-05-2021, 09:41 PM
Post: #40
Packed up.....
and on its way back to the client.......
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 3,556 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 7,177 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 4,870 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 3,165 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 2,558 06-28-2022 09:17 PM
