OST-048: Спасибо товарищ Сталин
05-02-2018, 11:08 PM
*raising hand* Macer seats sound good, could you a set for my Supertech assembly
Sent from my MHA-L29 using Tapatalk
AE86 ex-daily
05-04-2018, 04:25 PM
(05-02-2018 11:08 PM)Bean Wrote:  *raising hand* Macer seats sound good, could you a set for my Supertech assembly
check your PM
Dan -
05-24-2018, 12:45 AM
To be fair, the Supertech seat (shim) is "designed" around the dual spring configuration.
05-24-2018, 04:45 PM
(05-24-2018 12:45 AM)Project D Wrote:  To be fair, the Supertech seat (shim) is "designed" around the dual spring configuration.
completely agree... along with their guides for dual springs, and the seals for dual springs.
The complete kit is part of the reason I'm not a huge fan.
With that said, "complete kit", I called Ferria (not Supertech) and spoke to them about their "kit" (single spring and retainer - uses OEM spring seats). I called BECAUSE their single spring uses the stock seat. I got an interesting education.
Although the OEM spring, seat, and retainer all fit together nicely, they don't "lock" together. This absence of locking together allows each part to have different frequencies/harmonics - allowing higher wear. In an engine turning 8000+ rpm for 95% of its life, this is a big deal.
The locking together typically means there is an interference fit, as an example for those who have used Toda springs, they tend to snap onto(into) the OEM spring seat - locking the seat onto the spring. I'd be willing to bet(a nickel), that the Toda retainers also lock onto their springs.
The big but....... for engines that don't turn 8000+ rpm for 95% of their life... how important is it?? Toyota didn't think it necessary for regular use.... but what is "regular" use????
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 3,815 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 7,731 09-18-2022 02:19 AM
Last Post: oldeskewltoy
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 5,236 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 3,442 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 2,783 06-28-2022 09:17 PM
