OST-048: Спасибо товарищ Сталин
04-06-2018, 05:48 PM
As to the title.... Angel
[Image: AEU86 AE86 - OST-048: Спасибо товарищ Сталин]
While I've seen a few poor smallport castings.... this one is a pretty good casting, with decent chambers, and pretty good port-bowl alignment. What it doesn't have is a good short radius..... on ALL of the bowls.... Huh
more to come.... Hurray!
Dan -
04-06-2018, 07:37 PM
(04-06-2018 05:48 PM)oldeskewltoy Wrote:  As to the title.... Angel
Big Grin
Sent from my MHA-L29 using Tapatalk
04-07-2018, 01:32 AM
Big Grin
from another forum Wrote:I'll bite WTF does thanking Stalin for your happy childhood have to do with this? Try to avoid sniffing solvent my friend :omg:
Dodgy
In one of the email correspondences with this client..... "On my Cyrillic Russian keyboard when I typed "Спасибо товарищ" [thank you comrade] the next word suggestion that came up was "Сталин" [Stalin] ? looks like my phone is a cold war veteran & a good party member!"
more to come..... Big Grin
Dan -
04-10-2018, 05:50 PM
oldeskewltoy Wrote:[Image: AEU86 AE86 - OST-048: Спасибо товарищ Сталин]
working the short radius, and the port walls....
and further progress....
more to come..... Hurray!
Dan -
04-11-2018, 05:54 PM
Been a bit of a busy beaver......
Ports are almost done - ITB adapter AND this heads new Cat cams should arrive later this week
Intake bowls/seats are set, and the chambers deshrouded
and I've begun the exhaust side
and a bit closer (more detailed) view.....
Dan -
04-12-2018, 06:57 PM
from another forum Wrote:The before & after of the exhaust ports is especially noticeable!
2 down...., 2 to go.... then it goes off to get it's 3 angle......
more to come...... Hurray!
Dan -
04-16-2018, 10:47 PM
.... and now to get her 3 angle.....
Dan -
04-21-2018, 07:03 PM
now that the 3 angle is done, its time for checking chamber volumes........
all @ 37cc, so back to the shop for surfacing....
and then assembly with the new 252(222@ .050"), w/ 8.5mm lift [Image: AEU86 AE86 - OST-048: Спасибо товарищ Сталин]
Dan -
04-25-2018, 04:09 PM
So this engine will be using a set of ITBs. It will be using a T3 adapter.
The ITB adapter needs a bit of blending.....
As do the intake ports... they too need some gentle blending
I pick up the head later today, so more to come....... Hurray!
Dan -
05-02-2018, 05:16 PM
Assembly.... This client is using a Supertech spring/retainer kit.
I've not been a fan of the Supertech kit. One reason is because I've not been a fan of the Supertech spring seat....
Kind of a shame actually... as there are many springs out there that can fit the stock spring seat.
The Supertech spring seat is a flat steel "washer". There is nothing on the Supertech spring seat to help keep the spring located/stable in the spring pocket. Introduce the "Macer" spring seat.
Richard Macer builds many racing 4AGE heads, and he has found the standard Supertech spring seat to be "wanting", so he designed and had manufactured an improved spring seat
The Macer seat fits the spring pocket, and the inside "neck" helps keep the spring located, and stable.
If you want to get a set, send me a note, and I'll forward contact info.
Quote:I've not been a fan of the Supertech kit. One reason....
the other reason.... HELP! Supertech Retainer / stock buckets
I checked valve protrusion through the retainer, I have .025" on the exhaust side, and .030"+ on the intake side... so that concern is no longer a concern.....
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 4,205 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 8,589 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 5,852 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 3,901 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 3,098 06-28-2022 09:17 PM
