OST-043: Deutscher größerer Ventilkopf
03-07-2017, 10:24 PM
been awhile... they managed to fit me in....
[Image: AEU86 AE86 - OST-043: Deutscher größerer Ventilkopf]
OST-043 getting the seats removed, and machining the head to accept new seats.
more to come....... Hurray!
Dan -
03-09-2017, 02:47 AM
prepped... waiting for the next step
more to come..... Big Grin
Dan -
03-16-2017, 06:20 PM
from another forum Wrote:Which, will of course be, another flow test (before any port work) to determine the benefits of oversized valves in a 4age head.
Right?
Great opportunity to dispel any myths and supply genuine data in regards to this modification.
The ONLY work performed on intake #1 will be the 3 angle, and simple blending of the new seat into the bowl(less then 3/4" deep)....
... looking at the splitter that is evident.
The other 3 will get ported.
This view shows that the oversized seats in chambers #1 and #2 have been blended, but careful viewing inside chamber 1 shows the blending is only so deep, and that the guides are still untouched
A different view, this time at the mostly finished #2, and the yet to be started #3
More to come........ Hurray!
Dan -
03-16-2017, 11:21 PM
That's a awesome difference
Sent from my F3111 using Tapatalk
Signature removed due to large photobucket message
03-22-2017, 07:21 PM (This post was last modified: 03-22-2017 07:21 PM by oldeskewltoy.)
(03-16-2017 11:21 PM)MIGGZFSU Wrote:  That's a awesome difference
thanks.......... Wink
intake ports are done until after checking on the flowbench... which will come after cutting the 3 angle valve job.
Exhaust side next.......
more to come..... Hurray!
oldeskewltoy Wrote:Exhaust side next.......
2 down... 2 to go... Note these ports fit either the SV3 copper gasket, or the blacktop gasket
more to come.... Hurray!
Dan -
03-24-2017, 07:27 PM
from another forum Wrote:I always love watching your work.
Thanks!
The head is now ready to go back to the shop for it's 3 angle...........
The chambers are partially finished, major deshrouding has occurred, but final volume can't be set until the valves are set on their seats.
more to come...... Hurray!
Dan -
03-25-2017, 09:10 PM
Hmmmm, I missed a post.... Sad
Remember this head came with an ITB adapter. Well this ITB adapter is a well designed piece! I'm pretty sure it is a TecArt ITB adapter, and I'm a fan!
Once I did the taper on the intake port roof[s]... the intake adapter is such a nice fit Huh and notice the wonderful angle down now, instead of horizontal Wink
I wish I had @ my disposal a T3 adapter so I could put them both on the bench...
Dan -
04-04-2017, 05:49 PM (This post was last modified: 04-04-2017 05:50 PM by oldeskewltoy.)
The head is currently back @ the shop getting the seats cut, and checking valve protrusion.
In the meantime.... A bit of finishing work on the Tec Arts ITB adapter
more to come........ Hurray!
Dan -
04-21-2017, 02:13 AM
(04-04-2017 05:49 PM)oldeskewltoy Wrote:  The head is currently back @ the shop getting the seats cut
back in my care to get the bowls, and seats set to a consistent diameter, next week it goes back to have the cam clearances set, and then back in my care once again to set chamber volumes.
My client is using Mahle type F/A pistons, so chamber volume will be set to 37cc, to give him a static compression of 11.8:1
More to come.... Hurray!
Dan -
04-21-2017, 09:08 AM
Cams in the 280 range or is he going for lower DCR?
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 3,122 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 6,349 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 4,248 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 2,717 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 2,149 06-28-2022 09:17 PM
