OST-040: BOOOOSTed
08-16-2016, 10:37 PM
OST-040: BOOOOSTed
oldeskewltoy Wrote:all that is left to do... is set cam - valve clearances...... the cam sheet... with the the valve opening and closing events laid out.... ![]() 9.4mm of lift is getting close to requiring clearancing the head so the lobes don't hit.... but not quite ![]() setting clearances... spec is .20mm(.008") on the intake side, and .25mm(.010")... a thousandth is within tolerance. ![]() Final questions: What is actual valve lift on exhaust valve #4?? And on #3 exhaust valve? This head is now done, and will be heading back to it's owner shortly..... Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 3,867 |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 7,794 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 5,312 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 3,490 |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 2,819 |
![AEU86 AE86 - OST-040: BOOOOSTed [Image: AEU86 AE86 - OST-040: BOOOOSTed]](http://ost.ebeans.ch/albums/userpics/10005/cam_timing_with_overlay_noname.jpg)
![AEU86 AE86 - OST-040: BOOOOSTed [Image: AEU86 AE86 - OST-040: BOOOOSTed]](http://ost.ebeans.ch/albums/userpics/10005/cam_to_head_clearance___bucket.jpg)
![AEU86 AE86 - OST-040: BOOOOSTed [Image: AEU86 AE86 - OST-040: BOOOOSTed]](http://ost.ebeans.ch/albums/userpics/10005/cam_clearances_set.jpg)
