OST-034: Noir Crowning
08-06-2015, 05:27 PM
I got a request........
![]() More to come....
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
08-06-2015, 05:53 PM
Oh man.... sweet..!
08-06-2015, 06:19 PM
(This post was last modified: 08-06-2015 06:21 PM by Bean.)
Is it just me or does the 16V benefit more from porting than 20V regarding flow benefits?
AE86 ex-daily |
08-12-2015, 12:31 AM
(08-06-2015 06:19 PM)Bean Bandit Wrote: Is it just me or does the 16V benefit more from porting than 20V regarding flow benefits? lets see....... ![]() the intake side..... ![]() paper towel in exhaust port is acting as a "cork", remember these are used valves, in used seats, and stuffing the opposite port to the one being test allows for honest figures. The numbers @ 28"....... Unported Intake -
Ported Intake -
There is a glaring error on one reading, can anyone find it??? I likely over adjusted one valve, What should it read (about/approximate)?? setting up to do the exhaust side ![]() Unported Exhaust -
Ported Exhaust -
More to come......
08-24-2015, 08:20 PM
Nearly a 2 week delay...
I had a talk with my client, he is hoping for an exhaust to intake flow ratio approaching 80%. This is going to be extraordinarily difficult because the stock Blacktop flows about 61%, and the first attempt at porting the exhaust side did improve things, now 67%, but a further gain of 13% seems a long goal at best. My first attempt at porting the exhaust was limited because I didn't have a gasket to know where my edges were, and I didn't want to port beyond the gasket, for doing that would cause serious flow issues. So the initial porting on #4 exhaust was from about 33.6 to about 33.7, because not knowing the exhaust gasket left me a bit in the dark. My client sent me the OEM gasket ![]() Port on far right is #4, even with the gasket in the "down" position, there is still some room available in the port roof, and room all the way around the port. So now that I had a gasket, work begins on #2 exhaust port. Redline is the gaskets edge. ![]() A bit more dramatic.... ![]() The stock Blacktop gasket outlet is 36mm. Port #2 is now out to 34.8mm ![]() Later this week I'll get this on the bench and see what if any improvement there is over the first numbers. More to come........ Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
08-26-2015, 11:53 AM
(This post was last modified: 08-26-2015 11:53 AM by banpei.)
That's a lot of area you gained!
08-27-2015, 09:47 PM
oldeskewltoy Wrote: "New" exhaust port readings, #2 port - on right
The reason testing stopped @ .350 was my client is limited to 9mm of lift (.354") So now the intake @ .350" is @ 197.8cfm, while the exhaust is now @ 150.9, the exhaust to intake flow ratio is now a tick over 75% at peak lift, and over the lift range the exhaust to intake ratio is now about 71.5% (was 61%) More to come.....
09-04-2015, 01:46 AM
a few views of working the exhaust side.....
minimizing the guide boss, and tapering the guide - both to minimize their effect on the outgoing exhaust flow ![]() reshaping the exhaust port - maximizing flow ![]() 3 ports down.... one to go ![]() more to come.....
09-08-2015, 06:33 PM
09-09-2015, 01:36 AM
![]() Now to finish up the intakes and the chambers.... More to come.......
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 3,611 |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 7,299 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 4,934 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 3,203 |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 2,615 |
![AEU86 AE86 - OST-034: Noir Crowning [Image: AEU86 AE86 - OST-034: Noir Crowning]](http://ost.ebeans.ch/albums/userpics/10005/casting_compare_-_3_panel_annoted.jpg)
![AEU86 AE86 - OST-034: Noir Crowning [Image: AEU86 AE86 - OST-034: Noir Crowning]](http://ost.ebeans.ch/albums/userpics/10005/blacktop_mounted_to_flowbench.jpg)
![AEU86 AE86 - OST-034: Noir Crowning [Image: AEU86 AE86 - OST-034: Noir Crowning]](http://ost.ebeans.ch/albums/userpics/10005/head_set_on_bench.jpg)
![AEU86 AE86 - OST-034: Noir Crowning [Image: AEU86 AE86 - OST-034: Noir Crowning]](http://ost.ebeans.ch/albums/userpics/10005/dial_indicatior_set_for_exhaust.jpg)
![AEU86 AE86 - OST-034: Noir Crowning [Image: AEU86 AE86 - OST-034: Noir Crowning]](http://ost.ebeans.ch/albums/userpics/10005/exhaust_with_gasket_fittedup_and_down_2_panel_annoted.jpg)
![AEU86 AE86 - OST-034: Noir Crowning [Image: AEU86 AE86 - OST-034: Noir Crowning]](http://ost.ebeans.ch/albums/userpics/10005/What_I_do_ost-034_3_panel.jpg)
![AEU86 AE86 - OST-034: Noir Crowning [Image: AEU86 AE86 - OST-034: Noir Crowning]](http://ost.ebeans.ch/albums/userpics/10005/exh_port_2.gif)
![AEU86 AE86 - OST-034: Noir Crowning [Image: AEU86 AE86 - OST-034: Noir Crowning]](http://ost.ebeans.ch/albums/userpics/10005/exhaust_port_4_and_2_gasket_fit_port_shape_2_panel.jpg)
![AEU86 AE86 - OST-034: Noir Crowning [Image: AEU86 AE86 - OST-034: Noir Crowning]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - OST-034: Noir Crowning [Image: AEU86 AE86 - OST-034: Noir Crowning]](http://ost.ebeans.ch/albums/userpics/10005/one_bowl_done2C_one_yet_to_begin.jpg)
![AEU86 AE86 - OST-034: Noir Crowning [Image: AEU86 AE86 - OST-034: Noir Crowning]](http://ost.ebeans.ch/albums/userpics/10005/one_bowl_done2C_one_yet_to_begin3.jpg)
![AEU86 AE86 - OST-034: Noir Crowning [Image: AEU86 AE86 - OST-034: Noir Crowning]](http://ost.ebeans.ch/albums/userpics/10005/exhaust_3_down2C_1_to_go.jpg)
![AEU86 AE86 - OST-034: Noir Crowning [Image: AEU86 AE86 - OST-034: Noir Crowning]](http://ost.ebeans.ch/albums/userpics/10005/4_down_showing__1_exhaust_port_work.jpg)
