OST-032: Skippy gets a head
05-12-2015, 05:15 PM
(This post was last modified: 05-12-2015 05:15 PM by oldeskewltoy.)
Some of you know I've purchased a daily-able FX16 so I don't have to use Surreptitious(AE71) all the time...
![]() I named the FX "Skippy", and knew upon purchase that it didn't run. This is what was found when the head was pulled... something broke, and eventually got embedded - see arrow ![]() So.... OST-032 is Skippy's new head! ![]() stripped and ready for cleaning........ ![]() Can anyone tell me why one chamber is already clean???? More to come..... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-12-2015, 07:44 PM
Coolant leak into the cylinder ?
Leaking injector ? An analogue brain in a digital World |
05-12-2015, 08:20 PM
05-12-2015, 08:55 PM
(05-12-2015 07:44 PM)totta Crolla Wrote: Coolant leak into the cylinder ? (05-12-2015 08:20 PM)d3nso Wrote:(05-12-2015 07:44 PM)totta Crolla Wrote: Coolant leak into the cylinder ? normally these would be a great guesses.... But in reality this was a VERY loaded question - apologies ![]() ![]() ![]() more to come..... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-14-2015, 04:50 PM
Damn !
There I was thinking that if I post "because you cleaned it" you'd think I was taking the p*ss ! An analogue brain in a digital World |
05-22-2015, 04:16 AM
(05-14-2015 04:50 PM)totta Crolla Wrote: Damn ! can't win sometimes.... nature of carnival games ![]() So Skippy's head is back from cleaning and pressure checking. The chamber depths and the seat depth all look VERY good. There is some excess material that was left behind after the head was machined @ Toyota, that will all get cleaned up :thumbsup: ![]() It measures just about what an uncut head is suppose to measure - easily within the .001" tolerance of this caliper ![]() Work begins on chamber/bowls of #4 cylinder ![]() More to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-23-2015, 02:28 AM
oldeskewltoy Wrote:Work begins and continues....... ![]() @ cylinder #4.... deshrouding.... ![]() ...and working the exhaust.... ![]() 2 cylinders down, ![]() 2 to go.... more to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-27-2015, 03:04 AM
![]() It's far easier to take the direct path......then the path with the bend ![]() more to come....... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-28-2015, 04:51 AM
oldeskewltoy Wrote:It's far easier to take the direct path......then the path with the bend bends are gone...... ![]() more to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-29-2015, 01:15 AM
![]() Now that the casting has been massaged... It'll go off to the shop on Monday to get its 3 angle, and have the head surfaced. More to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,931 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 5,972 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,970 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 2,508 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,995 |
