OST-030: a case in point
04-08-2015, 06:22 PM
![]() Got this via FedEx yesterday.... ![]() I've gotten heads in all kinds of containers/packaging. But this one is unique, and lead to the title..... It has very interesting latches.... ![]() I wish all clients would be able to do this....... ![]() Safe and secure with plenty of protection around it ![]() the head is clean, and it comes with all the hardware.... ![]() ..... along with a set of Pon cams!!!! More to come.......
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-09-2015, 02:32 PM
That's a flight case, often used by musicians and such.
The latches are very similar to those used in Military cases (non Peli type) as they have a high latch strength and low profile
04-09-2015, 07:44 PM
(04-09-2015 02:32 PM)mad.matt Wrote: That's a flight case, often used by musicians and such. from another forum Wrote:hmmm...military owner by any chance?...we use those cases for equipment/parts Now I (we all) know about this kind of case/latch :thumbup While OST-031 is being cleaned and pressure checked, it gives me a few days to work on OST-030... Besides the Poncams, my client is using a piston with a 3.2cc dome. He has to check, but believes he has .005" of positive deck - piston slightly ABOVE the blocks surface. He wants to run a squish of .040". What chamber volume does he need for a 11.3 to 1 compression ratio? My clients said his head had been already run through the mill once... .008" ![]() Seems pretty close to me.... btw... look at the "round" exhaust port... ![]() All the cam journals look pretty much the same as this... ![]() Since MR2tailbreaker noticed a "small" problem in his cam and journal clearances using the Poncams, I'll be checking these journals for similar issues..... Work begins on the bowls and seats of chamber #1 ![]() More to come....
04-10-2015, 08:17 PM
from another forum Wrote:What do you do about bad cam journals and caps? not ignoring you... not quite ready yet to show that part of the process ![]() from another forum Wrote:Is this a CA customer? 11.3 on 91 octane, better have clean chambers, and management dialed in nicely, my recommendation from experience... I would even worry that improved breathing/VE would skew things even more toward a little less CR. If this is 93 octane, probably it's fine, but potentially close to incipient detonation. Other side of the country..... Part of the issue is opening the chamber to accommodate the piston. With the clients deck, and the piston volume, the chambers may need to be "opened". Most pistons can be milled a few ten thousandths, which could drop the piston volume under 3cc example of piston milling ![]() The piston I designed could be milled .030" and drop the dome volume from 2.5cc to about 1.8cc. Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-11-2015, 12:59 AM
#1 is almost finished...
![]() Here is #1 exhaust bowls/port in transition ![]() And a closer view of the short radius, and the port in the background ![]() More to come.......
04-14-2015, 01:14 AM
2 down.... 2 to go.....
Chambers..... ![]() exhaust ports..... ![]() More to come.......
04-15-2015, 12:17 AM
further progress... 3 down 1 to go....
this time the intake view - first short radii... ![]() followed by the view down the ports ![]() The exhaust... ![]() And the chambers... 3 panel this time so you can see the progression ![]() More to come.....
04-16-2015, 02:52 AM
4 down......
![]() ![]() Next stop valve job and resurface... and then we set chamber volume.... More to come.......
04-17-2015, 12:48 AM
oldeskewltoy Wrote:Besides the Poncams, my client is using a piston with a 3.2cc dome. He has to check, but believes he has .005" of positive deck - piston slightly ABOVE the blocks surface. He wants to run a squish of .040". Here is what is now known.... 82mm bore or 3.229" 77mm stroke or 3.031 .012" piston sticks out of the bore .052" Cometic gasket 3.2cc piston dome So I ask again what chamber volume does this build need to have a static CR of 11.3 to 1??? Now how do I achieve that target volume on a head already cut .008", and will be cut an additional .002"???? Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-17-2015, 06:07 PM
from another forum Wrote:If all else remains the same and assuming the bore of the head gasket is 1mm larger than the cylinder bore then you need a volume of 37cc.I should have had you answer these other responses ![]() from another forum Wrote:Without checking it.. from another forum Wrote:oh, and account for the gasket too. so chamber volume will need to be As to the chamber volume I'll need... I find to save time, and poor calculating skills on my part - I use one of the online compression calculators..... https://www.rbracing-rsr.com/compstaticcalc.html or http://www.csgnetwork.com/compcalc.html either of these work..... in both cases we come up with about 37cc (37.3 in the RB racing calculator) Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 3,588 |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 7,230 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 4,892 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 3,184 |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 2,592 |
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/ost-030.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/As_arrived____.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/latch_gif.gif)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/case_opened1.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/case_opened.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/case_opened3.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/115_80.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/journal_scratching.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/intake_bowls__1.gif)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://i79.photobucket.com/albums/j143/oldeskewltoy/MOmo/machinedpistonforloweringcompression.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/chamber_view__1_done.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/exhaust_bowl_view_chambers_1_and_2.gif)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/_1_exhaust_bowls_port.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/chambers_2_down_2_togo.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/exhaust_2_down_2_togo.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/normal_intake_short_radius_3_down_1_togo.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/normal_intake_view_3_down_1_togo.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/normal_exhaust_view_3_down_1_togo.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/normal_chamber_3_panel.jpg)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/intake__4.gif)
![AEU86 AE86 - OST-030: a case in point [Image: AEU86 AE86 - OST-030: a case in point]](http://ost.ebeans.ch/albums/userpics/10005/chambers.gif)
