OST-029: California here I come.....
01-27-2015, 02:58 AM
[Image: AEU86 AE86 - OST-029: California here I come.....]
exhaust port #2 mid work
Chambers 4, 3, and now 2 deshrouded
Intake short radii on 4, 3, and now 2....
More to come...... Hurray!
Dan -
01-30-2015, 03:24 AM
from another forum Wrote:Looks real good especially the short turns and the chambers.
exhaust #1
all the chambers
More to come........ Hurray!
Dan -
02-11-2015, 12:02 AM
oldeskewltoy Wrote:[Image: AEU86 AE86 - OST-029: California here I come.....]
More to come........ Big Grin
After the cut, with the valves fitted... waiting for checking chamber volumes....
This head was cut .018" (.457mm) My caliper can't figure out if it is .45, or .46
"Volumes" to come........ Hurray!
Dan -
02-12-2015, 02:40 AM
from another forum Wrote:Since this head is coming here to Cali. Is the customer going to do any kind of camshaft or just use the stockers? I'd be curious I know that my web cams in my N/A engine wouldn't pass smog.
Really? which Webs? My AE86 used the Web 294 grind and they passed, albeit with a new OEM type cat, but they passed. And I'm pretty sure OST-019 passed using a mild cam, but it needed a bit of ignition timing tweaks to pass.
Most likely my client will be running a set of the "big", or early stock cams if he can get himself a good pair. There is a Cat cam that MIGHT work, its their shortest, lowest lift cam, it measures 214 @ .040" lift, with a gross lift of 8 mm. The Web 294 cam is 214 also, but @ .050" lift.
oldeskewltoy Wrote:"Volumes" to come........ Big Grin
Checking chamber volumes on the cut head.... it is down to 35.1cc (tolerance = + or - .1cc)
So we can move on... besides waiting a week for the machine work, that same time was used to get new springs....
16 new OEM springs...
Now its just left too assembly.....
More to come..... Hurray!
Dan -
02-12-2015, 10:09 AM
How big is the gain in head flow after a makeover like this? Do your have any before/after measurements?
02-13-2015, 01:33 AM
(02-12-2015 10:09 AM)harkes Wrote:  How big is the gain in head flow after a makeover like this? Do your have any before/after measurements?
The exhaust side is virtually the same work, so the exhaust side has been flowed before.
The intake side I've not as of yet flowed in this configuration.... but as you can see below, much of what I do is the same. This head was a little conservative, but not extremely so....
Amazing what isn't seen...
A great deal... but its all there. From the top view you miss out on #1, and much of #3 but #2 and 4 are quite evident.
Since this is a California head I've left the swirl generators, but managed to adjust their shapes to something a bit more uniform, one needs a bit more work - does anyone know wtf I'm talking about :lol:
Quote:Did it get the super 5 angle valve job?
3 angle with back cut intakes
Dan -
02-15-2015, 09:36 PM
from another forum - non USA Wrote:California ? would those mod affect the ca emission drama on there ?
They shouldn't....... Nothing I've done is actually drastic. For the most part I'm just improving the original casting by port matching the seats-bowls-ports to more closely match the original design. The surface machining of .018" is not beyond the normal range. A multi angle valve job is not beyond typical. The slightly raised compression will not hurt either.
The client has selected to run a pair of MILD upgrade cams. He purchased 2 exhaust cams from Cat Cams 7105136 on my recommendation. They have the same timing as the OEM cams, they have a bit more lift, and a bit more duration... without it going to an extreme (emissions unfriendly)
from another forum Wrote:What are swirl generators? I can see everything else you pointed out thanks.
First apologies... the more common, and in this case correct term is actually "tumble generators"
This kind of tumble generator promotes lower air speed performance by causing the incoming air to rotate as it approaches the valve. The theory is it helps to fill the valve area better. It also may act as a passive emissions device... to further aid in air-fuel mixing so more complete combustion can occur.
More to come.... Hurray!
Dan -
02-19-2015, 01:05 AM
Video OST-029: California here I come.....
Installing valve #8... apologies to AC/DC... my timing was off by about a second.... Angel
Dan -
02-19-2015, 06:20 PM
haha, nice one
02-20-2015, 12:17 AM
The valvetrain is now assembled....
Cam caps buffed....
Just waiting on those new cams.....
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,951 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 5,996 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 4,021 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 2,530 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 2,012 06-28-2022 09:17 PM
