OEM LSD modification
02-05-2013, 01:00 PM
Post: #31
malejyetti Wrote:Hi DRFT, No, no, no. size is very appropriate. Deviation from the original, with a sample, is minimum. ![]() http://ae70.blogspot.com/ & http://drft.io.ua/ |
02-05-2013, 01:01 PM
Post: #32
malejyetti Wrote:Under the widht of the tooth you have to place only inside plates the outside plate doesn't have to be there... I know that. My mistake in the translating... ![]() http://ae70.blogspot.com/ & http://drft.io.ua/ |
02-05-2013, 01:04 PM
Post: #33
Bean Bandit Wrote:well that still makes it 3 plates instead of one... anyhow at ~1mm per plate that seems doable.. Drawings of my plates were left at plant were they were made. I can't get them... But I still can order plates there at any time and any quantity. Besides, I have 4 plates left... ![]() http://ae70.blogspot.com/ & http://drft.io.ua/ |
02-05-2013, 10:25 PM
Post: #34
If anyone is willing to share the technical drawing for the plates I wouldn't say no to having them - else I'll just have to wait untill I find the time to pull it all apart myself one day.[/quote] Hi It will last. As I said before it was abused one season with ported Blacktop and the seccond season with the F20C swap. This video with F20C swap prooves it works perfectly..
JZD |
02-21-2013, 07:18 PM
Post: #35
More than a week ago I gave my clutches to the plant, so that they would be polished to the desired sizes.
Today I was planning to take them ready. But it turned out that with the OEM clutch was a problem. OEM ones together with those that are laser cut from steel 65G clutch are kept on a magnetic table grinding bridge. OEMs do not stay on the magnetic table and create problems. So we lost 2 clutchs. ![]() ![]() ![]() ![]() ![]() However, the clutches that was laser-cuted good magnets and well polishing. So I left the extra clutches and next week I was promised to finish polishing. ![]() http://ae70.blogspot.com/ & http://drft.io.ua/ |
03-28-2013, 12:29 AM
Post: #36
Steel, which I chose for these plates, with increasing content of magnesium. Not so easy to work with.
And here is another victim of inexperienced plane grinder. ![]() ![]() But the change of several "artists" with the right machine, we were able to make things right. ![]() ![]() ![]() So now we can assemble. ![]() There is clearly seen that at the same thickness that had only 3 disks before. Now same thickness have 5 discs and it will provide, according to my calculations, +66,7% increase area of friction. From 94.2 to 157 square cм*. ![]() ![]() ![]() ![]() ![]() ![]()
04-24-2013, 10:57 PM
Post: #37
I have got some of the new babies
Here I have some more of the LSD plates - part of them is ready for my friend. and some spare. ![]() ![]() Then I have some new idea !!!! Spool modification.. And you don't have to weld anything, also you can turn it back to LSD easily.
JZD |
Post: #38
3€ for the dxf files sent to your e-mail ..
To donate my ideas.. (: JZD |
06-23-2016, 11:56 AM
Post: #39
I need more information on these....
I have a OEM Kouki LSD ready for putting in my 86. What would be the % of locking of the OEM LSD? I want to improve the locking % of my LSD, so is there any kit available for the LSD? Regards |
06-23-2016, 12:27 PM
(This post was last modified: 06-23-2016 12:28 PM by d3nso.)
Post: #40
Afaik the OEM LSD is in the 25% range. There are some kits arround which add additional clutch plates to improve locking like the ones in the post above.
| Fuel Tank Modification | apardal | 1 | 7,424 |
08-11-2014 06:59 PM Last Post: Ivan141 |
| OEM LSD Question | heshan | 26 | 31,538 |
07-19-2014 08:18 AM Last Post: heshan |
| All I should know about suspension before any modification | damusto | 20 | 30,175 |
05-24-2013 09:28 PM Last Post: damusto |
| OEM lsd rebuild kit and exterior parts | NightAddict | 6 | 11,229 |
01-07-2013 11:01 PM Last Post: T_AE86 |
| ae86 oem lsd | Captainl | 3 | 7,060 |
07-05-2011 08:48 AM Last Post: Captainl |
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://i120.photobucket.com/albums/o196/DavidGilson/gilly.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://g.io.ua/img_aa/large/2425/84/24258488.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://g.io.ua/img_aa/large/2425/84/24258490.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://g.io.ua/img_aa/large/2425/84/24258492.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://g.io.ua/img_aa/large/2425/84/24258494.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://g.io.ua/img_aa/large/2425/84/24258499.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://io.ua/24380489n.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://io.ua/24380490n.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://io.ua/24495909n.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://io.ua/24495959n.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://io.ua/24521275n.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://io.ua/24521296n.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://f.io.ua/img_aa/full/2452/67/24526782_f.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://io.ua/24521298n.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://io.ua/24521299n.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://io.ua/24521300n.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://io.ua/24521303n.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](http://io.ua/24521305n.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](https://www.aeu86.org/files/p2/p2280109_209.jpg)
![AEU86 AE86 - OEM LSD modification [Image: AEU86 AE86 - OEM LSD modification]](https://www.aeu86.org/files/p2/p2280128_416.jpg)
