OBX Exhaust Systems
07-03-2009, 02:08 PM
OBX Exhaust Systems
Ok, I did a full measurement of the inner pipe diameters of the OBX exhaust system and its scary.
Header first piece connected to the head. 51MM end pipe
First connection pipe on the header is 48mm ?????
Then you miss the catalytic converter
The end pipe starts at 49mm and the last piece over axle is 56mm
??????? So if I look at the system I would say I can scrap the mid sections and make em custom. That way I can increase diameter of the piping from 51mm from the header to 56 in the end. instead of making the air collapse onto stainless steel plating.
I have to calculate the perfect flow. I guess the first piece and last piece are of good value but the mid sections just suck ...... So if you can weld stainless steel you can turn this into an amazing exhaust but if not Its a good one for a slightly modified engine. But if you really start tuning the flow will be so fucked up that it will cost a lot of performance.
I will post pictures when I mount it to the car and show what kind of mid section I will create
08-11-2009, 02:47 PM
OBX Exhaust Systems
How much does it weigh Lennert? I'm going to add 40 odd kilograms to the nose of my car so need to lose some weight there...also Ivan will be wanting his header back some time in the future.
Could you throw it onto some scales for me? Dumb question
12-13-2009, 08:07 PM
OBX Exhaust Systems
NoHachi Wrote:How much does it weigh Lennert? I'm going to add 40 odd kilograms to the nose of my car so need to lose some weight there...also Ivan will be wanting his header back some time in the future.
didn't weight it but the system weighs alot less than standard. Think Oldskull still has the header seperate.
12-13-2009, 08:10 PM
OBX Exhaust Systems
yeah got the header here. but you dont have 4age under your trueno right?
12-13-2009, 08:11 PM
OBX Exhaust Systems
Now the full info
The OBX system was build for a exhaust with catalyst converter.
[Image: AEU86 AE86 - OBX Exhaust Systems]
The missing piece
The fill up
The result
Conclusion, the OBX system is a cheap way to replace original. Its loud and doesn't come with a silencer. The quality is decent. Thought I had to weld a small leak in the connector part of the header (wasn't welded shut)
If you are handy the OBX system is a good "upgrade" from original but don't think its direct swap.
12-13-2009, 09:55 PM
OBX Exhaust Systems
You forgot to mention that it nearly touches the chassis floor under your feet. This wouldnt be important to mention if you werent using cusco lower engine and gearbox mounts that bring the engine down a notch.
There's a good chance that it simply would foul the chassis otherwise.
Also you have shortened the rear silencer mount and it is still quite low to the ground (the bend before it goes up over the diff). And you had to weld a hole shut that was left open on the flange of the downpipe.
Just a warning so people dont go thinking it is a good fit, because it just isnt.
For the money it is not strange that you have to do some modding to fit it, as robo demonstrated it can be pulled off with some minor welding.
12-14-2009, 11:59 AM
OBX Exhaust Systems
Drako in here from Greece had the same problems I think.
Oh, and I had similar on the Miata. Big Grin
[Image: AEU86 AE86 - OBX Exhaust Systems] http://www.jdmbits.com
12-14-2009, 12:49 PM
OBX Exhaust Systems
nmwisima Wrote:Drako in here from Greece had the same problems I think.
Confirmed!
Mine is a 4-2-1 header and I had to recurb the entire thing. See pics in: http://www.aeu86.org/viewtopic/ae86/t/42...start=2300
sorry its in greek...
SFD
02-20-2010, 07:19 PM
OBX Exhaust Systems
stay away from obx pure con artist's dont waste ur money!!
02-20-2010, 07:40 PM
OBX Exhaust Systems
sanfrancam explain please.
  Good news: new rwd 4AGE header, Bad news: OBX oldeskewltoy 6 11,538 06-11-2011 04:54 AM
Last Post: Celica RA45
  Aircon: Converting R12 systems to R134A Lauren 1 6,601 06-04-2011 04:21 PM
Last Post: Lauren
  Comments about the OBX Helical LSD? heshan 4 8,631 04-27-2011 11:19 PM
Last Post: mikeyee
  OBX Headers fits or not? Allexz 8 12,385 03-12-2008 12:14 PM
Last Post: SutteR
  OBX Header byd1380 4 8,515 12-17-2007 02:26 PM
Last Post: diz9
