NoHachi's KE25 corolla coupe
09-20-2006, 08:49 AM
Post: #91
Levin,
Hehe well I think my tires may actually still make MOT, not sure.. we'll see Big Grin
but if not, I'll either use the 13" I still have in the barn (unless nohachi pics em up) or take you up on your offerBig Grin
I've still got some nice rimms from Oldskull but haven't gotten round to putting tires on them. Thinking about putting new tires on them and using my current set as drift practice tires when the time comes...
09-21-2006, 01:37 PM
Post: #92
Just got a call from Toyota, they have my window waiting for me at the dealership..check! Not bad just a 3 day wait for the last KE-25 window remaining in Europe. Time to check with the panel beater when he will be ready to accept my car.
09-21-2006, 04:11 PM
Post: #93
Ok, took the gamble on a set of 5cm lowering blocks.. Will have to see whether they fit either the KE or the volvo..
I need to figure out whether I will be needing shortstrokes or not.
Doc: could you maybe crawl under your car and confirm whether the rear shockmounts are a part of the leafspring mount or whether they are mounted straight to the axle? Much appreciated!
09-21-2006, 10:17 PM
Post: #94
for my spethial KE2* friend i made this picture Wink
[Image: AEU86 AE86 - NoHachi's KE25 corolla coupe]
Mounted straight to the axle it is Smile
09-21-2006, 11:02 PM
Post: #95
Ah Thomas, thanks a lot! Guess I will be looking for shortstrokes pretty soon then. I heard that some corolla's had them mounted onto the leaf spring mounting plate..That would have meant that the stroke always stayed the same and very easy swapping of axles too...Oh well..guess we'll have to do it the hard way then.
09-22-2006, 10:49 AM
Post: #96
Found a pic from a TE28 rear suspension..These do have the shocks mounted onto the spring platforms. Funny how the complete suspension setup seems different between relatively similar models...
It does make me wonder whether it is possible to retrofit these spring platforms onto the KE...it would make the swap to the LSD axle housing VERY easy indeed!
09-22-2006, 03:56 PM
Post: #97
i think it has something to do with the station shape.
If i'm right, the KE26 also has a different rear suspension setup as the Coupe and Sedan.
Need to look it up at the parts catalogue to be sure, but i guess it's the same.
//edit:
Need to say this: What a f*cking clean underside!
Mine isn't even close to that Smile
09-22-2006, 04:12 PM
Post: #98
I think they should be able to be retrofitted to the KE-XXs too..That would mean that you don't have to weld new shock brackets to an LSD axle and also that you eliminate the need for shortstrokes and can run all the cheaper normal stroke ones.
Problem is..where to find the things..I believe some of the later KE-3X series cars also had these platforms.
09-22-2006, 04:20 PM
Post: #99
KE26's are very rare overhere, someone from TACN is searching for one for quite a long time, but zero to none.
Maybe Mark knows how the rear shocks where mounted on his KE30, he should've seen it many times Smile
09-22-2006, 09:36 PM
Post: #100
The Doctor Wrote:KE26's are very rare overhere, someone from TACN is searching for one for quite a long time, but zero to none.
Not so many as I've seen the ta40s (4 sets on it now, 1 year)
The upper mount was under the rear seats
The lower ones...I don't know...
But they're not that difficult as on the ke20
I think it's similar to the ta40/ae86 I think
Mark
  Corolla GT Coupe - Royalty Black pack 269 336,060 05-15-2026 04:40 PM
  Mikzu IV ae86 from Luxemburg+ shuttle + ke25 + 280z + chaser Mikzu IV 151 227,859 06-21-2012 08:05 PM
Last Post: bozu
  my 8a9 corolla GT coupe cloko 24 50,777 01-30-2012 05:17 AM
Last Post: Sambo
  My UK TE71 Corolla SR Coupe Finished.... japclassics 8 19,619 01-11-2011 02:12 PM
Last Post: Pacsker
  RaceMinded satin black Toyota Corolla AE86 Levin Coupe RaceMinded 22 38,540 09-02-2010 07:25 PM
Last Post: Apolan
