Need help with the Headlights, One light doesn’t retract
12-29-2007, 06:58 PM
On the trueno One light is up and doesn’t retract any clue on how to solve the issue, I have tried for several times to move the light switch on the panel thorough all the positions but still up the left headlight is up.
12-29-2007, 08:23 PM
If the other one is working OK it should not be the switch.
Check for: -Loosen or broken actuator rod -Broken connector wires -Actuator is working fine (take him out, and plug the negative and positive terminals of the battery to the 2 main and thick connector of the socket. Exchange the polarity, if nothing works buy a new actuator) Easy ![]() |
12-29-2007, 08:30 PM
JonnyAE86 Wrote:If the other one is working OK it should not be the switch. Thanks Jonny Where is the actuator located? |
12-29-2007, 10:16 PM
![]() I solve the problem the retractor was on the left side near the headlight, I need a new one, this one has been repaired due to all the adhesive it has. Do anyone knows the average price of it? |
Need help identifying this! | takumi_mt | 4 | 1,947 |
TRD ECU need help | ps13michi | 5 | 5,448 |
Need some help | DJexor | 4 | 6,352 |
03-13-2018 05:37 PM Last Post: pack |
Weak spark, doesn’t start. | AlexFourTwenty | 4 | 17,344 |
JDM trueno not starting. need help! | kazi | 8 | 10,268 |
