Need help with the Headlights, One light doesn’t retract
12-29-2007, 06:58 PM
On the trueno One light is up and doesn’t retract any clue on how to solve the issue, I have tried for several times to move the light switch on the panel thorough all the positions but still up the left headlight is up.
12-29-2007, 08:23 PM
If the other one is working OK it should not be the switch.
Check for:
-Loosen or broken actuator rod
-Broken connector wires
-Actuator is working fine (take him out, and plug the negative and positive terminals of the battery to the 2 main and thick connector of the socket. Exchange the polarity, if nothing works buy a new actuator)
Easy
[Image: AEU86 AE86 - Need help with the Headligh...’t retract]
12-29-2007, 08:30 PM
JonnyAE86 Wrote:If the other one is working OK it should not be the switch.
Check for:
Easy
Thanks Jonny Where is the actuator located?
12-29-2007, 10:16 PM
I solve the problem the retractor was on the left side near the headlight, I need a new one, this one has been repaired due to all the adhesive it has.
Do anyone knows the average price of it?
  Need help identifying this! takumi_mt 4 1,973 04-05-2024 09:17 AM
Last Post: takumi_mt
  TRD ECU need help ps13michi 5 5,475 02-18-2022 10:42 AM
Last Post: ps13michi
  Need some help DJexor 4 6,378 03-13-2018 05:37 PM
Last Post: pack
  Weak spark, doesn’t start. AlexFourTwenty 4 17,368 12-12-2017 03:35 AM
Last Post: AlexFourTwenty
  JDM trueno not starting. need help! kazi 8 10,295 03-12-2017 05:05 PM
Last Post: kazi
