My new rebuilded denso starter (Heat soaked?)
10-01-2012, 08:26 AM
Hello mates,
i was for a ride..i did about 70kms .When i was going back i did a stop to see my granny for about 20 minutes.So i got into the car, when i try to turn her on the f@cking tak (no cranking just tak and again tak) for about 20 minutes :-( .Is this heat soak again ?i have the reduction starter now...i was thinking about the heat shield i am using under the hood maybe deflects and increace the temperature at engine bay finally? 4age 16v to FR 20VT |
10-01-2012, 08:56 AM
Hows your battery? I had this once with a nearly dead battery, it couldnt supply the huge start current demanded by the starter and would just go click (or f@cking tak as you so eloquantly put it ;-)).
Before going crazy with other solutions, try to borrow a decent battery and try that out. If the starter actually starts turning before slamming to a halt then you might have an ignition timing problem, but that's relatively rare. That would result in the starting troubles when hot as well, but it's a very different click to the one where the starter wont start turning (louder). FABRICA MI DIEM, PVNC! |
10-01-2012, 09:47 AM
Hello mate and thanx for your fast answers....
My battery is good condition!It was 12.69 Volts when i arrived from home and generally plays from 12.60 and above.It is 45amp but i dont have measure her to a battery shop My ignition timing was set to 10 degreess 2 days ago so what do you propose? 4age 16v to FR 20VT |
10-01-2012, 10:19 AM
Trying another battery is not difficult, and good to rule out. If you swap starters first and then find out it is the battery it would result in a huge face-palm.
If the starter is the problem, then there are shops that are specialized in repairing them. About heat soak: do you still have the original heat shield on the starter? And the one beneath the exhaust manifold? I have driven without the exhaust heat shields without problems, but Holland is a usually colder than Greece. FABRICA MI DIEM, PVNC! |
10-01-2012, 11:25 AM
You didn't ask your granny for a push start...
Did you ? ![]() Also check the Earth straps very carefully, engine to chassis and battery to chassis. An analogue brain in a digital World |
10-01-2012, 12:36 PM
totta Crolla Wrote:You didn't ask your granny for a push start... HAHAHAHA guys the starter is rebuilded and unsused...... i have it for a month and that happends yesterday where i was on a ride and i made a stop for a few minutes....and then i tried to turn her on... this situation happends first time to me ... and yes the starter and the exhaust have heatshields! 4age 16v to FR 20VT |
10-01-2012, 07:18 PM
lol
10-01-2012, 07:43 PM
totta Crolla Wrote:Also check the Earth straps very carefully, engine to chassis and battery to chassis. mate my said that it should be the contacts if i am saying it right... http://www.toyodiy.com/parts/p_E_1988_TO...l?hl=84312 4age 16v to FR 20VT |
| AE86 starter options | max_ae86 | 12 | 34,666 |
07-28-2019 08:17 PM Last Post: harkes |
| Starter problems | Widar | 49 | 139,512 |
02-09-2015 10:11 AM Last Post: Ivan141 |
| Starter Motor Help | phill 92 | 3 | 6,915 |
11-25-2013 11:16 AM Last Post: Apsogos |
| Starter motor questions - rebuild | Jezza_hr | 6 | 9,790 |
08-31-2013 03:05 PM Last Post: Apsogos |
| 4AGE Heat Shielding Intake Gasket | asyrigos | 11 | 26,413 |
04-01-2013 10:58 AM Last Post: asyrigos |
lol
