My cluster shows wrong speed.?
03-10-2008, 05:44 PM
Ah that explains a lot! Big Grin Big Grin
SR5 got 4.1, so 4.88/4.1 = 119! Hurray!
19 -> 22 will solve it almost, you can do the rest with the tiresize. Wink
[Image: AEU86 AE86 - My cluster shows wrong speed.?]
03-10-2008, 06:35 PM
thanks alot!
Don“t Think About The Past,
Live In The Present And
Dream About Tomorrow
03-11-2008, 09:50 AM
Allexz Wrote:ive have the volvo 240 rear axle w the 4.88 in ratio
Photos please !
03-11-2008, 08:26 PM
Check SK's project for pics of a volvo 240 axle on a hachi..
03-14-2008, 03:10 PM
Thanks !
I have 240 rear axle 1030 type bought for another car, good to see that it fits nicely !
Is it true that all Dana 35 CWP and LSD options will fork for it ?
03-14-2008, 03:45 PM
Dana 30 if I'm not mistaken.. If it's a 1030 then the R&P will fit, if it's the later 1031 axle, then you can only use the diff cause it has beefier R&P gears.
If your looking into this, could you possibly find out what the difference is between the DANA diffs for different ratio R&P's? They have 2 models, one goes up to 3.6 or 4.0 ratio, and the other one for higher ratio's.
My volvo 360 has a 1031 style rear diff, so it would be interesting to know what to look for, and if there are differences that I should look out for.
03-14-2008, 03:53 PM
Ivan141 Wrote:Dana 30 if I'm not mistaken.. If it's a 1030 then the R&P will fit, if it's the later 1031 axle, then you can only use the diff cause it has beefier R&P gears.
So the question is about 2 models Dana 30 diffs - up to 4.0 ratio and over it ?
What is the difference, compatibility for CWP also ?
Yes, I'm sure my rear end is 1030, I bought it exactly for Dana max. compatibility in order to use cheap options from USA Thumbs up!
03-17-2008, 12:38 PM
I asked in local Jeep forum and the answer was:
Quote:For Dana 30 and 35:
3.55 and lower CWP use smaller differential unit, 3.7 and higher use big one.
03-17-2008, 07:33 PM
So which one matches the volvo unit size-wise? I'm pretty sure volvo used one type of lsd for the whole range of r&p ratio's, at least they did on the 360's with 1031 diff (which should be the same as a 1030 but with beefier bearings on the pinion gear, and thus different r&p sets).
03-18-2008, 10:26 AM
They are Jeep community and know nothing about Volvo, I suspect that I must measure/compare my Volvo 1030 diff with some Dana 30 from their offroad cars.
  EUDM gauge cluster banpei 22 14,360 08-15-2023 10:48 PM
  EUDM cluster revelations banpei 1 3,348 06-23-2023 09:11 AM
Last Post: r.ave
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 12,315 11-09-2020 10:51 AM
Last Post: totta Crolla
  Custom Dash Cluster kazi 14 28,769 10-24-2017 09:05 PM
Last Post: kazi
  EDM GT-S Cluster, PWR light VSV? Rascal21 1 5,722 06-25-2017 08:00 PM
Last Post: Rascal21
