My cluster shows wrong speed.?
03-10-2008, 12:25 AM
I think it shows 20km/h to fast. when im going around 100km/h.
My tyres is 185/60/14. I thought about setting 195 or 205/55/16 Any help. ive do not have the gts tranny Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
03-10-2008, 12:29 AM
look at your T50 speedo gear...if it is a 19toothed one i have got a brand new 22toothed one to sell you and fix your problem...
AE86 FANATIC!!! |
03-10-2008, 10:35 AM
That won't fix it completely: your speedo will measure 110 when driving 120 then...
http://www.tiresizecalculator.info/ Did you change the rear axle from SR5 to GTS? 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
03-10-2008, 01:06 PM
bit offtopic and a bit not
![]() My km/h gauge stopped working and the km counter too. Rev gauge and lights of cluster works. Anybody knows why?? 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
03-10-2008, 01:30 PM
DJexor Wrote:bit offtopic and a bit notThe cable from the gearbox to the cluster is broken... Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch
03-10-2008, 02:06 PM
Jan Pedersen Wrote:The cable from the gearbox to the cluster is broken... Oke thanks, can you tell me where that cable is located exactly at the gearbox? 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
03-10-2008, 02:14 PM
@Jor: It can't be hard to find, it just a cable going trough the firewall that mounts to the top of the gearbox, fitted with a ring that is probably made of plastic. If you unscrew the ring (by hand) you can pull it off the gearbox. The other end is mounted to the back side of the cluster with a plastic clamp.
03-10-2008, 02:44 PM
@ Allexz : If you have a 19teeth speedo gear and change it to a 22teeth you 'll solve the problem ...
AE86 FANATIC!!! |
03-10-2008, 03:34 PM
Don't expect 100% correct readings. Any car manufacturer "insure" that readings are a little higher than real speed.
I think that your problem is not technical - if your speedo shows 120km/h with real speed ~100 or little higher. |
03-10-2008, 04:52 PM
ive have the volvo 240 rear axle w the 4.88 in ratio
| EUDM gauge cluster | banpei | 22 | 14,726 |
| EUDM cluster revelations | banpei | 1 | 3,385 |
06-23-2023 09:11 AM Last Post: r.ave |
| 4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 12,478 |
| Custom Dash Cluster | kazi | 14 | 28,981 |
| EDM GT-S Cluster, PWR light VSV? | Rascal21 | 1 | 5,764 |
06-25-2017 08:00 PM Last Post: Rascal21 |
![AEU86 AE86 - My cluster shows wrong speed.? [Image: AEU86 AE86 - My cluster shows wrong speed.?]](https://www.aeu86.org/sticker-banner-468.gif)
