My cluster shows wrong speed.?
03-10-2008, 12:25 AM
I think it shows 20km/h to fast. when im going around 100km/h.
My tyres is 185/60/14.
I thought about setting 195 or 205/55/16
Any help. ive do not have the gts tranny
Don´t Think About The Past,
Live In The Present And
Dream About Tomorrow
03-10-2008, 12:29 AM
look at your T50 speedo gear...if it is a 19toothed one i have got a brand new 22toothed one to sell you and fix your problem...
03-10-2008, 10:35 AM
That won't fix it completely: your speedo will measure 110 when driving 120 then...
http://www.tiresizecalculator.info/
Did you change the rear axle from SR5 to GTS?
[Image: AEU86 AE86 - My cluster shows wrong speed.?]
03-10-2008, 01:06 PM
bit offtopic and a bit not Wink
My km/h gauge stopped working and the km counter too. Rev gauge and lights of cluster works. Anybody knows why??
03-10-2008, 01:30 PM
DJexor Wrote:bit offtopic and a bit not Wink
The cable from the gearbox to the cluster is broken...
03-10-2008, 02:06 PM
Jan Pedersen Wrote:The cable from the gearbox to the cluster is broken...
Oke thanks, can you tell me where that cable is located exactly at the gearbox?
03-10-2008, 02:14 PM
@Jor: It can't be hard to find, it just a cable going trough the firewall that mounts to the top of the gearbox, fitted with a ring that is probably made of plastic. If you unscrew the ring (by hand) you can pull it off the gearbox. The other end is mounted to the back side of the cluster with a plastic clamp.
03-10-2008, 02:44 PM
@ Allexz : If you have a 19teeth speedo gear and change it to a 22teeth you 'll solve the problem ...
03-10-2008, 03:34 PM
Don't expect 100% correct readings. Any car manufacturer "insure" that readings are a little higher than real speed.
I think that your problem is not technical - if your speedo shows 120km/h with real speed ~100 or little higher.
03-10-2008, 04:52 PM
ive have the volvo 240 rear axle w the 4.88 in ratio
  EUDM gauge cluster banpei 22 12,565 08-15-2023 10:48 PM
  EUDM cluster revelations banpei 1 2,935 06-23-2023 09:11 AM
Last Post: r.ave
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 11,500 11-09-2020 10:51 AM
Last Post: totta Crolla
  Custom Dash Cluster kazi 14 27,447 10-24-2017 09:05 PM
Last Post: kazi
  EDM GT-S Cluster, PWR light VSV? Rascal21 1 5,405 06-25-2017 08:00 PM
Last Post: Rascal21
