My Red Panda :)
12-19-2005, 09:39 AM
My Red Panda :)
Man, there is some bloke sitting in your car on this picture
![]() http://oldskull.sytes.net/hachi/DSC03897.JPG Nice garage btw. ![]() Drifting - best fun you can have in your car with your pants on! |
12-19-2005, 06:23 PM
My Red Panda :)
@banpei: Thanks for your offer but its solved. Today I visit friend of friend of mine. My friend told me his friend know lot of car electrical. So I can give him a try. So my plan B is to ask you if he can't. But he fixed up. I am so happy with it
![]() @ae82_gt: Yeah this need to clean up soon, I need some advis to clean up because I dont know what I need to use to clean them up. Yeah Ivan is right, the owner bring the car from Swirtzerland to Netherland about 8 years ago. @James: Yeah I will come back to the last owner in January, seem I have 3 months garanty so he will do some check up. So I will ask him to replace those oil. He did replace them before I bought it, so in January should be ok to replace new one. @ZaX: The bloke are the new owner of the car now ![]() ![]() ![]() ![]() Yeah I must say the garage are very nice and big. I wish I have those too. ![]() ![]() |
12-19-2005, 09:07 PM
My Red Panda :)
oldskull Wrote:@banpei: Thanks for your offer but its solved. Today I visit friend of friend of mine. My friend told me his friend know lot of car electrical. So I can give him a try. So my plan B is to ask you if he can't. But he fixed up. I am so happy with itSmall hint: I used an Mitsubishi (1996+) ISO harness and remodelled it to a toyota according to this link: http://www.dorikaze.ca/dorikaze_guides_d...php?a_id=2 This is the pin-layout: [code:1] 1983 to 1986 Wiring Harness: Pin What It Does Colour In Dash New Harness Match 1 Right Front Speaker (+) Green Gray 2 Left Front Speaker (+) Pink White 3 Right Front Speaker (-) Blue Gray w/ Black Stripe 4 Left Front Speaker (-) Purple White w/ Black Stripe 5 Ground Wire Black Black 6 +12 Volt Ign Wire Gray Red 7 Power Antenna Wire 1 Blue (join wires 1 &2 together 8 Power Antenna Wire 2 to this blue wire) 9 Do Not Use 10 Right Rear Speaker (+) Red Purple 11 Right Rear Speaker (-) White Purple w/ Black Stripe 12 +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow 13 Left Rear Speaker (+) Black Green 14 Left Rear Speaker (-) Yellow Green w/ Black Stripe [/code:1] Then you can place any ISO-connector compatible radio in your hachi. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
12-19-2005, 09:56 PM
My Red Panda :)
Hey thanks for those layout. I am planning to put ISO-connector when I bought new cd player. So I can use this!! thanks again banpei
banpei Wrote:Small hint: I used an Mitsubishi (1996+) ISO harness and remodelled it to a toyota according to this link: |
12-20-2005, 12:01 AM
My Red Panda :)
oldskull Wrote:Hey thanks for those layout. I am planning to put ISO-connector when I bought new cd player. So I can use this!! thanks again banpeiI've done mine a few months ago and know how much pain it is to find the correct data. ![]() I asked at three dealers if they knew anything, visited various car-parts shops and searched the internet and still found nothing. ![]() Lucky enough I found the mitsubishi connector looking familiar. ![]() I also found the mitsubishi pin-layout, it's the second one. Unfortunately only in pdf. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
12-20-2005, 06:30 PM
My Red Panda :)
Thanks again banpei.
Someone here in Holland got pair of wiper in good condition for sale? ![]() There is old stickers on my back and front window. I would like to remove them, any suggestion to remove them without damage the glass? thanks |
12-20-2005, 07:26 PM
My Red Panda :)
Quote:Someone here in Holland got pair of wiper in good condition for sale? You can order them new ![]() |
12-20-2005, 07:33 PM
My Red Panda :)
oldskull,
like ae82_gt mentioned, just go to your local toyota dealer and ask them to order them for you. They dont cost much more then the wipers you can get at hallfords or whatever. Does anyone have part numbers for these? I need some aswell ![]() as for the stickers, heat them up with a blowdryer or something. Be carefull with this but the stickers should let go pretty easily when warmed up. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
12-20-2005, 08:34 PM
My Red Panda :)
ah ok, I will get them from toyota dealer around here, oh yeah maybe someone got part number? darn i dont have any hairdryer
![]() ![]() ![]() today the engin timing seems to be bit beter, cold about 2000rpm and warm about 1200rpm. but still strange when i press clutch pedal (koppeling) the timing up very fast. when I lose it and it drop back. anyway I hope this will solve soon. |
12-20-2005, 09:37 PM
My Red Panda :)
Partnrs;
Blade lh 85220-14390 Blade rh 85220-16280 arm lh 85210-12180 arm rh 85210-12610 Let your dealer check them because there can be a number change |
