My 1986 ae86
12-27-2011, 08:23 PM
Post: #51
My 1986 ae86
Ok thanks,now its gone
![]() Some updates tar day 2: http://i43.tinypic.com/2vua26b.jpg http://i41.tinypic.com/nf5wuw.jpg http://i40.tinypic.com/ou5tti.jpg If i calculated correctly the entire tar removal will be arround 20-22 kg Like said,its pretty clear now that there is rust behind this http://i44.tinypic.com/8z0nco.jpg Weird holes in the floor? Looks perfect to get lines to the inside of the car http://i43.tinypic.com/fku2b4.jpg __________________ |
12-27-2011, 11:20 PM
Post: #52
My 1986 ae86
Nice work with the tar removal.
Those holes are also easy to spray anti-rust coating inside the frame-rails. ハチロク
12-28-2011, 09:42 PM
Post: #53
My 1986 ae86
thanks.
Yes indeed,would be perfect to fill them out from the inside 75% today,getting really boring ![]() left rear and mid http://i39.tinypic.com/34yrwqs.jpg Aargh 2 rustspots,looks like hard ones to fix http://i40.tinypic.com/2i0ugcx.jpg http://i41.tinypic.com/2wmowuc.jpg Hm im wondering if i also should remove the tunnel tar in the front,what do you think? http://i43.tinypic.com/2cpaywg.jpg |
12-28-2011, 09:46 PM
Post: #54
My 1986 ae86
Yes you should remove al the tar !!
saves a lot of weight i took 25 KG out of mine '87 levin coupé |
12-29-2011, 10:58 PM
Post: #55
My 1986 ae86
100% done finally
The total was arround 20kilo of tar pic http://i41.tinypic.com/1zprxjs.jpg should anyone what the blue item in middle is let me know ![]() came from heater somewhere,it was behind the tunnel. more rust http://i41.tinypic.com/i21r13.jpg |
12-31-2011, 05:44 PM
Post: #56
My 1986 ae86
So today is the day i inspected the worst rust spots
on the lift point or around and from below http://i43.tinypic.com/245hsoj.jpg http://i44.tinypic.com/qqtr0h.jpg left behind http://i39.tinypic.com/28aud8y.jpg roof http://i40.tinypic.com/no7ehy.jpg right wheel http://i41.tinypic.com/10cw0md.jpg http://i43.tinypic.com/2rf3ue1.jpg hard spots to fix i think,will i need to cut out the bars/floor? |
12-31-2011, 06:56 PM
Post: #57
My 1986 ae86
I see some familiar sights there, and some odd ones too.
The floor rust is not typical.. you really should inspect it further by removing the undercoating around the rust. If it rusts towards the sill you might be in for a bigger job than it looks. Just the floor is an easy fix. The bit near the rear wheel floor is also one I've never seen before. Looks like it's right above the chassis crossbeam that the panhard support sits on. Interested to know how this spot got rusty in the first place. The spot behind the rear seat is a very typical disaster area on zenki ae86's/ Thank Toyota and their 4/5 layers of sheet metal in a vulnerable area. Look at my project thread to get an idea of what things will look like underneath (the holes where patched up on mine but if you look at the welded bit's you get the picture). Rust underneath the roof is an odd one too.. Only other car I've ever seen it on is our Trueno here.. it's standing-still on the street for extended periods of time that does this too hachi's I reckon. The roof is currently off the trueno to fix that...you could try keeping it at bay with some acid & rustconverter for the time being though. FABRICA MI DIEM, PVNC! |
01-02-2012, 05:41 PM
Post: #58
My 1986 ae86
Thanks for the information,im at a loss to why some spots are rusted :s
MY thought is that there came water from the bars at the bottom. spot 1 i still dont have a clue how it got there. I think it came from the opening between the 2 lift points spot 2 probably trought the bars at the bottom,no idea that it is near the panhard is a concearn for me spot 3 i have started with the wheel and found out where it came from,see picture http://i41.tinypic.com/23vxc35.jpg spot 4 the roof i think it must have been with the sunroof somehow right behind wheel another rustspot which looks like trouble http://i40.tinypic.com/10naonc.jpg and the bottom part is also rusting http://i43.tinypic.com/xll2mx.jpg |
01-22-2012, 03:29 PM
Post: #59
My 1986 ae86
some updates:
por 15 on the wheel arch http://i39.tinypic.com/1zp2zo1.jpg welding http://i39.tinypic.com/dcanhv.jpg http://i44.tinypic.com/23kvtq1.jpg http://i41.tinypic.com/ip9xms.jpg http://i41.tinypic.com/1cjv4.jpg steering knuckles(only have driven the car to shop after and they turn alot better) http://i39.tinypic.com/5ehelk.jpg heatshield and nst brake stopper http://i44.tinypic.com/aetu1h.jpg http://i40.tinypic.com/m4o02.jpg decided to take the roof out http://i44.tinypic.com/2zsy1qx.jpg |
01-29-2012, 07:01 PM
Post: #60
My 1986 ae86
Some bad news
Car might have been in an accident The measurements from the ae86 manual on the forum are not the same as on my car Are those the correct measurements for the european model too? that would be really bad news :'( I still can't find any damage on the car so i have no idea if and where the car took damage |
| 1986 Toyota Corolla Levin 2dr GT-Apex | ondafly | 52 | 13,171 |
09-11-2026 09:56 PM Last Post: banpei |
| 1986 Corolla SR5 S2k Build.... MIami style | geoscranny84 | 16 | 29,051 |
04-26-2012 08:00 PM Last Post: [Walaki]D`Lair |
| Saw the light -> My 1986 AE86 project | IBMFD3S | 37 | 44,188 |
08-08-2011 02:13 AM Last Post: IBMFD3S |
