My 1986 ae86
11-27-2011, 11:37 PM
Post: #41
My 1986 ae86
To answer a few of your previous questions,
don´t go to crazy about your intake system!!! Silicon reducer, hardpipe, headshield, airfilter. Job done, I run a hose from behind the bumper to behind the headlight to draw in some fresh air. I do belive carpets are the same on 2dr´s and 3dr´s (exept for the boot carpet) no matter if its SR5 or AE86, the gearstick hole is differnt on automatics. I run NGK iridium spark plugs, they´re a little more expensive than OEM, but well worth it, much nicer spark. Watch for the right heat grade, tho! About the fan conversion, I don´t really like the viscous fan, they get old, have poor efficiency and will steal a little power from your engine (rotating mass). A proper electric, even better termostatic, setup will be better. It also leaves you with more space in front of your engine, very handy if you work on alternator/cambelt etc. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
11-28-2011, 05:57 PM
Post: #42
My 1986 ae86
Thanks for the answers
![]() That would be great,planning on using the carpet for the back for inspection and normal driving. If i check this guide For NA cars usually use a grade 6 for most road applications, a grade 7 can be used in hi compression race type cars, grade 8 in extreme rev/compression cars. grade 6 looks like the right choice then? |
12-01-2011, 06:40 PM
Post: #43
My 1986 ae86
pic
12-01-2011, 06:47 PM
Post: #44
My 1986 ae86
pic?
12-03-2011, 05:02 PM
Post: #45
My 1986 ae86
Installed the trd cables.
Also replaced the distributor cap and rotor arm,they were showing there age. pics http://i41.tinypic.com/678t21.jpg http://i42.tinypic.com/34gmvkg.jpg |
12-04-2011, 01:08 AM
Post: #46
My 1986 ae86
Hm still trying to find the problem i have.
The bushings look fine Sounds from the back i tried to make a video of it http://youtu.be/SZN5mfiwRyc anyone have any idea? |
12-25-2011, 01:14 PM
Post: #47
My 1986 ae86
updates:
replaced the bfront bumper brackets,they were broken and not even attached http://i44.tinypic.com/91exk3.jpg beginning rust removed http://i41.tinypic.com/noy5og.jpg http://i43.tinypic.com/16c5cn7.jpg gearbox cleaning http://i40.tinypic.com/33aqeeh.jpg ordered AP Racing PRF660 brakefluid ordered brake booster heat shield ordered terratrip intercom system I have also decided on the rollcage i will be using,the design is like this(forgive my drawing skills) http://i40.tinypic.com/amdrbo.png because of regulations the last part will be before the trunk part of the coupe,so not cutting wil be done there like this http://i43.tinypic.com/25oxdug.jpg Would it be a good idea to remove the tar and replace it with por15? I can't see any starting rust this way and it weights probably alot I will also remove the tar from inside and then repaint it |
12-26-2011, 12:06 AM
Post: #48
My 1986 ae86
ditn Wrote:updates: I hope you didn't pay to much for those side brackets. I took these off and threw them away. ハチロク
12-26-2011, 07:12 PM
Post: #49
My 1986 ae86
7,5€ for both
Anyone have any idea which cable this is http://i40.tinypic.com/35k936d.jpg http://i40.tinypic.com/f9e4at.jpg Comes from leftside but was not connected and disappears in the roof music cable? And a small update http://i39.tinypic.com/2vb0ux1.jpg removing deadening soud material |
12-26-2011, 07:29 PM
Post: #50
My 1986 ae86
Cable seems to be from the roof antenna.
ハチロク
| 1986 Toyota Corolla Levin 2dr GT-Apex | ondafly | 52 | 14,528 |
09-11-2026 09:56 PM Last Post: banpei |
| 1986 Corolla SR5 S2k Build.... MIami style | geoscranny84 | 16 | 29,448 |
04-26-2012 08:00 PM Last Post: [Walaki]D`Lair |
| Saw the light -> My 1986 AE86 project | IBMFD3S | 37 | 45,123 |
08-08-2011 02:13 AM Last Post: IBMFD3S |
