My 1986 ae86
10-26-2011, 10:57 PM
My 1986 ae86
So im starting to check the little problems i have
![]() The dashboard back light isnt working: speed revs petro but climate interior light clock rear & front lights works. anyone an idea what this could be? When the engine is just starting the rpm is standing @ 2200 and after warmup @1000rpm,is this normal?(I thought arround 1500 was ok) update: i lowered it a bit,sits arround 800/900 rpm now Also im looking for the best points to lift the car on a (2 palen brug) 2 pole car bridge? in front right side of the T in back not so sure,hard to see since car is pretty low ![]() another picture http://i40.tinypic.com/243jkfs.jpg ? |
10-28-2011, 08:02 AM
My 1986 ae86
lets see:
dash backlight not working: broken rheostat in light switch. You can bypass it with a wire or fit another light switch. (it's the resistor that makes the light adjustable). RPM: 2200 is not unusual. Silly but true. Jack points: I try to avoid 2 pole bridges like the plague. They will leave your floor a dented mess. Best thing to do would be to make some slotted bits of wood that fit around the seem under the sills (where the original jack points are), then put the swing arms under those. Shouldnt be too difficult, but trust me it is worth it in the end. I've a couple of cars with dented chassis because of those crappy bridges. FABRICA MI DIEM, PVNC! |
10-28-2011, 04:36 PM
My 1986 ae86
thanks for the answers
![]() Im making something like you said to protect the car. Its a wooden piece with some rubber om top of it to protect the seem under thejack point. 2 pole bridge is only option i had,not enough space. |
10-28-2011, 07:44 PM
My 1986 ae86
this is what i made,
some wood with parts from my old taekwondo protector(ribpart which has material for shock absorbing kicks,pretty good i think) http://i40.tinypic.com/1z21vgx.jpg Removed the rear bumper,it was pretty dark but i dont think i saw any rust http://i43.tinypic.com/35mnrq0.jpg Will need to go shop to the eruoshop again because some bolts snapped off |
10-29-2011, 09:15 PM
My 1986 ae86
Today i have been cleaning the engine bay
airfilter and box was really dirty,found even bird feathers in the box http://i39.tinypic.com/2qdd2qp.jpg http://i40.tinypic.com/j73yfm.jpg the breather system from the ae86 is quite unique to me with the airbox and then another bosx underneath there,why is that? Also what is the green plug and the other cable you can see in the fourth pic? cleaning engine bay: http://i40.tinypic.com/2jdoqd2.jpg http://i40.tinypic.com/6s5jyb.jpg result day 1 cleaning http://i40.tinypic.com/9r58ba.jpg used old towels,lots of dirt http://i44.tinypic.com/219z04y.jpg also removed the front strut bar,possible rust detected and last looking for some items,you can find them in this thread http://www.aeu86.org/viewtopic/ae86/p/142326#142326 |
10-31-2011, 08:21 PM
My 1986 ae86
ordered some piece from the toyota dealer today for the rear bumper bracket
some pictures workplace http://i41.tinypic.com/n2dhle.jpg 1600 16v old & new power FF and FR ![]() http://i42.tinypic.com/350747r.jpg |
11-01-2011, 08:18 PM
My 1986 ae86
So after some advice from Ivan i made these
http://i40.tinypic.com/b802zs.jpg On the bridge http://i42.tinypic.com/2dkhfmd.jpg some pics from the bottom,as you can see alot of tar whas put on the underside of the car. http://i42.tinypic.com/i708ax.jpg http://i40.tinypic.com/14jswlz.jpg http://i40.tinypic.com/2cs9gdd.jpg Found some repairs two,those are well done. |
11-03-2011, 10:54 PM
My 1986 ae86
oil day
engine oil out,my oil wrench for 106 gti doesn't fit so will need to buy another one LSD oil changed gearbox oil changed kart engine oil changed ![]() Found another unconnected cable. |
11-04-2011, 01:36 PM
My 1986 ae86
Got some questions:
Does anyone know what this cable is for,was hanging loose in engine bay http://i42.tinypic.com/ab5g5l.jpg Also those 2 cables: http://i40.tinypic.com/6s5jyb.jpg green and white connector cables. 1 was loose in engine bay and other is attach to the second small box from the airbox. |
11-04-2011, 05:43 PM
My 1986 ae86
First one is the oil pressure connector. Try to catch besides de Oil Filter a small metal thinguie, that connector slides and locks there, to give you exactly the oil pressure level!
The second one, i got it myself hanging there, but with a cap... it must be for AC or Power steering... Regards |
| 1986 Toyota Corolla Levin 2dr GT-Apex | ondafly | 48 | 9,103 |
08-07-2026 09:27 AM Last Post: ondafly |
| 1986 Corolla SR5 S2k Build.... MIami style | geoscranny84 | 16 | 28,172 |
04-26-2012 08:00 PM Last Post: [Walaki]D`Lair |
| Saw the light -> My 1986 AE86 project | IBMFD3S | 37 | 42,404 |
08-08-2011 02:13 AM Last Post: IBMFD3S |
