Mocal oil cooler & sandwitch plate ordered
05-14-2008, 01:17 PM
Post: #31
saw your remote termostat.. got more pictures of that ?
cheers,
Roel
05-14-2008, 02:52 PM
Post: #32
Nothing any more detailed than what you can see here.
[img name=]http://www.aeu86.org/files/re/remote_thermostat_824.jpg[/img]
Note I have used press fit hose and fittings so you make your own lines - easy.
I made my own bracket. A little cumbersome but I wanted to make use of existing bolt holes only, not drill any new ones.
When thinking about placement, remember to factor in the impact the fittings will make to relative heights and clearance.
05-14-2008, 06:57 PM
Post: #33
that I understand,
Andwhat kind of thread have you used? and the thickness of the hoses etc...
and where is the oil cooler of you positioned ?
couse I think that I will place the oil cooler in front of the normal radiator,
but take in account that I wil place a FMIC in the near future..
with other words.. how mutch hose will I need? I dont think that I will Use a relocator for my filter, so will bolt the relocator directly th the engine..
for as I can see, that should be possible. will take an other close look.
These are the parts that I got in mind sofar..
MOCAL pressed plate oil to air coolers ( I think that a normal one will do just fine no needs for a HD pressed plate coolers)
OC5193-8
COOLER 19ROW 230MM 1/2BSP MALE
£91,12 (Excluding VAT at 17.5%)
Oil Cooler Take Offs
OTSP1
For spin-on 3/4UNF filter- tapped1/2BSP with built in oilstat
£38.72 (Excluding VAT at 17.5%)
Female 45o fitting
2x for on the sandwitch plate
HEFP43-8
1/2BSP for 1/2 hose- Moquip steel
£5.25 (Excluding VAT at 17.5%)
2x for the sandwitch plate
MMS3-8-8
1/2BSP x 1/2BSP- steel
£0.96 (Excluding VAT at 17.5%)
Female 90o fitting
2x for on the cooler
HEFP93-8
FC332 "Socketless" Hose
4 meter (need about 1,7 meter from oil filter to the front x2 )
FBN0800
1/2" bore, 0.75" od - black- per metre
£7.51 (Excluding VAT at 17.5%)
this in adition if the hoses are delivered in 4 x 1 m ...
Male straight fitting- non swivel
2 x for the hose long length needed.
HEMP3-8
£1.70 (Excluding VAT at 17.5%)
Female straight fitting
2x for the hose long lengt neeeded
HEFP3-8
do I miss annything ??
05-15-2008, 08:34 AM
Post: #34
1/2 " push fit hose. I ordered 3 metres and I had quite a bit left over, even after I decided to change one of the hoses.
1/2 BSP thread for the fittings.
For a 1600cc naturally aspirated engine a 13 row cooler is heaps. This cost me GBP 59 but then they gave me 25% off everything.......
I have placed mine as low as possible in front of the radiator at the bottom right corner as you look from the front of the car. It is placed hard up against the radiator core. The hoses run through the oval shaped hole under the battery tray. I enlarged this slightly and modified an oval shaped rubber blanking plug I found on the front of an MX83 Cressida. Drilled holes in this for the hoses and there is no way the hoses will ever rub on the body work.
Make sure you place the cooler so the inlet/outlet is at the top, not the bottom, to minimise risk of airlocks.
The guys at Think Auto really know what they are doing so let them know what you are planning and they will tell you what you need. You can actually get a kit ready made up for an AE86 with hoses and all.
05-15-2008, 09:53 AM
Post: #35
Owkee thanx Parrot,
For placing; I measured from oil filter straight to the side, unther the batery troug to the front and want to place the cooler untherneat the hood lock...
(so I have plenty of room left for my intercooler..
Are the hoses delivered in pieces of one meter or just in one piece??
The current engine is a 4agze, and not natural aspirated engine, and I was given the advice by a dutch rally shop to take at least the 16 row, but the 19 row was perfect they said..
ow btw, why did you got 25% discount ?? Big Grin
Hope that they will awnser my email shortly Big Grin
thanx sofar!
Cheers Roel
05-15-2008, 11:32 AM
Post: #36
Hose came in one piece.
Re discount, I was passing through the UK on the way back from Brussels and was trying to arrange a VAT exemption form. Had the parts delivered to my brother in law in the UK. In the end, they found it all too hard so just knocked 25% of the total bill!!
05-20-2008, 10:27 AM
Post: #37
Did It take so long for you to get a reply by them Parrot?
cause I emaild them last week and still got no reply..
will call them today..
05-20-2008, 10:45 AM
Post: #38
It did actually, but that was because they were in the middle of changing over to a new server. Obviously shouldn't be a problem now. Perhaps the person is on holidays.
But yes, give them a call, they were very helpful.
05-22-2008, 03:36 PM
Post: #39
those englisch guys are realy slow.. damnzz..
spoke to them on the phone.. during that, I emaild them.. they said.. owkee. we are going to arrange that.. (cause I wanted a quote first..)
2 days after .. still no reply..
trough some friends who do allot in Peugeot tuning .. (engine tuning)
DP-engineering.nl I got the adress of http://www.dutchpowertrading.nl
and what do you know.. they also sell Mocal.. and for even better prices!!
they only cant shring/ fit a hulse on the joint...
So I called a compagny who can do that.. and can also deliver hoses etc..
So will order complete hoses for a nice price over there! with fitted joints..
and the Mocal oilcooler 19 row 330 mm width is ordered.. maybe a little overkil at the moment.. but does not mather that mutch! its is perfect for a little more power in the future Big Grin
also a sandwitchplate inc termostat... Smile
I'm happy now.. at last.!!!
Dutch powertrading also has got nice Intercoolers.. witch i need.. Big Grin hmm..
cheers Roel
05-27-2008, 03:22 PM
Post: #40
Hi guys.
Do you think is it a problem to have oil temp always at 75-80 celsius when racing/drifting?
I bought a too big (35*30*5cm - 25row) oil cooler. I use it with the mocal thermostat adapter, but the temp won't rise over the opening temp I think.
  Oil cooler totta Crolla 0 2,891 07-25-2021 03:25 PM
Last Post: totta Crolla
  Oil cooler kit izanagi 7 11,572 09-20-2016 11:13 AM
Last Post: harkes
  Permanent oil cooler vs thermostat Lt86 19 27,672 03-28-2015 06:54 PM
Last Post: Lt86
  trans oil, lsd oil change Apolan 9 21,943 10-01-2014 03:57 PM
  Spindle dimensions, backing plate bolt pattern Rascal21 18 29,029 03-13-2014 11:45 AM
Last Post: Rascal21
