MSD 8980 setup - which wire does the dizzy connect to?
11-19-2011, 03:20 PM
Hi all,
I'm in the final stages of my carbed 4AGE setup but I need to know which cable goes from my 4age dizzy to the MSD 8980 timing computer.
the dizzy has 3 wires going out a white, blue and red which needs to connect to the white going into the MSD timing computer but which one?
thanks
[Image: AEU86 AE86 - MSD 8980 setup - which wire...onnect to?]
11-22-2011, 04:27 PM
anyone. its a very common mod when carbing a 4age. someone must know
11-22-2011, 06:29 PM
Please post a wiring diagram of the MSD.
What signal does the MSD require? RPM or ignition impulse?
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
11-22-2011, 06:44 PM
It depend of your dizzy (and the signal that the MSD need)
VIOLET wire from MSD should be connected to RED OR BLUE wire from the dizzy (I would say the RED)
and the GREEN wire to the WHITE from dizzy.
BTW I don't run on carb nor MSD, I just read the MSD manual so I may be wrong.
Try, since it's a VR sensor they're is no risk to damage anything Wink
11-22-2011, 06:47 PM
it requires an ignition pulse.
which upon further research means it will be using the green & violet cables:
http://www.msdignition.com/WorkArea/Down...x?id=16233
still not sure what it needs to connect to in the way of the dizzy
11-22-2011, 06:51 PM
open your dizzy and look which wire goes to the sensor front of the wheels with 4 teeth -> this is the wire you will need Wink
(the white wire is the ground for both sensors)
11-22-2011, 06:58 PM
cool I had a look when fitting the rest of the unit and if its the 4 teeth sensor then i know which cable to use. thanks Thumbs up!
11-22-2011, 07:02 PM
1 tooth = 1 spark so 4 cylinders = 4 teeth Cool
  20v BT - which oil pump? Mylesmck 4 6,082 06-21-2022 04:51 PM
Last Post: pack
  Rim width. Which is best.... Dino86 5 10,115 01-07-2017 03:09 PM
Last Post: Dino86
  Anyone know what this plug does? Super86 3 9,022 08-01-2016 03:57 PM
Last Post: Nakilad
  which connector is this ditn 7 11,547 07-27-2015 11:24 AM
Last Post: pack
  Haslbeck front spoiler, which foglights? wouter86 2 7,313 02-15-2015 11:14 AM
Last Post: ditn
