MAP ECUs / Ignitors / Dizzy etc..
03-28-2008, 03:43 PM
Hi all.. Id purchased what is supposed to be a redtop (hicomp) MAP setup off a guy, received the box tonite from a buddy who picked it up for me and Im finding some weirdness that google and searching the forum hasnt helped..
Can anyone ID what I've actually got here:
2 ECU's..
89661-20130 - can't find record of this anywhere, yellow connectors..
89661-12130 - this appears to be a bluetop MAP ecu from the UK..
Dizzy -
19100-16040 - not the right-angle redtop cap Im used to, standard bluetop cap on it
Coils / Igniters -
90919-02183 - Odd rectangular coil with small 2 pin connector in potting
19070-15120 / 89620-12270 looks like whats on the bluetop in my DD (not sure on part # tho)
89620-20241
and then a couple map sensors
89420-12010
89421-20040
Any help figuring out what Ive actually got here is appreciated.. Im supposed to be using it to run my hicomp redtop but Im thinking Im up the creek..
thanks,
Brett
03-29-2008, 12:56 AM
These are numbers from a JDM Hi-Com smallport...
90919-02198 Coil, encapsulated, two-wire plug
19100-16250 Distributor, wires from side of cap
89420-12040 MAP Sensor
Cheers... jondee86
03-31-2008, 05:16 PM
great, thank you for the info..
Brett
01-27-2009, 10:01 PM
89620‑20241 igniter of celica 4age 85-87
have you it?
**COROLLA EE80 - 4AGE 124HP**
[Image: AEU86 AE86 - MAP ECUs / Ignitors / Dizzy etc..]
Big Grin map sensor cheating? fdsjakl890 8 3,981 08-26-2025 01:12 PM
  AFM to Map Conversion ps13michi 3 6,393 01-06-2022 10:34 AM
Last Post: ps13michi
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 18,706 02-10-2020 06:39 PM
Last Post: Power_uP
  extracted freedom ecu 16v ignition map ditn 7 12,865 08-22-2016 10:01 AM
Last Post: ditn
  smallport question AFM or MAP? fax0815 5 11,486 05-17-2014 05:07 AM
Last Post: jondee86
