Levin - Trueno Questions
02-24-2012, 10:58 PM
Post: #31
Thanks! Thumbs up!
02-29-2012, 05:58 PM
Post: #32
Any news banpei?!
03-08-2012, 02:32 PM
Post: #33
Got the connectors for the clearance lights. CE100 and AE92 models use them too! That part is solved!
New questions! I've got some problems finding the connector references for my relays, i have some images from them and i even got some more information via electrical schemes elsewhere on the car.
The problem is that i can't find any reference from those 6 pin connectors. Is there any place on the web, or anyone that could help me get references? Or maybe find some other car sharing those same 6pin connectors.
Same issue about the headlight motor connectors. Where can i find references from those? Those are easier to deal with, just cut the wiring and adapt some new male/female plugs.
Regards
03-08-2012, 02:43 PM
Post: #34
I lost you there after the third connector(s) - what do you need?
03-08-2012, 03:04 PM
Post: #35
hahahaha true! Didn't read what i wrote.... Damn... so many connectors!
Just need some references about those, or any info from where can i get similar ones. =)
03-11-2012, 06:54 PM
Post: #36
Got everything i needed except the male connectors from the clearance lights..... Where could i possibly find those?
Meanwhile....
My electrical scheme doesn't exactly match the manuals....
I'll explain everything
My actual connector at the car (the white one)
[Image: AEU86 AE86 - Levin - Trueno Questions]
But on the Levin electrical scheme it is...
The colours are different! What's escaping me here?
Need some help please. Thanks
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 9,461 05-26-2024 07:40 PM
Last Post: totta Crolla
  Windscreen stoopid(?) questions.... Mylesmck 7 5,274 04-30-2024 09:46 PM
Last Post: Mylesmck
  Sub panel and rotary-button replacement for Levin -> Trueno conversion gh0st 9 11,658 11-05-2021 08:17 PM
Last Post: gh0st
  Brake Bias Questions mad.matt 10 17,434 01-03-2019 04:54 AM
  wider rear axle,track width,suspension questions ditn 6 13,510 10-18-2016 11:50 AM
Last Post: fantapants
