Levin Coupe from Croatia - NOW SR86 with IRS
12-06-2005, 03:25 PM
Post: #291
Bearing for the rear axle. Just pictured
Fun is not the straight line! |
12-06-2005, 03:41 PM
Post: #292
Damn ZaX
12-09-2005, 03:57 PM
Post: #293
Nice ZaX!
12-18-2005, 06:00 PM
Post: #294
After a bussines trip this week, I finally got some time to work on the car.
I instaled the thermostat since car didn't have one. Car wouldn't warm to working tempertaure and it was cold inside these days. Somebody instaled 2 or 3 gaskets so I had to use dremel tool to clean up the surface on water pump to prevent leaking. Other then that I replaced my windscreen wipers with new ones, replaced cable for openin the hood, since old one broke, mounted the front mask and mounted the front license plate. I still have to fix side indicators fuse, horn, rear glass heater, co-drivers doors... It's cold to work in garage so I doubt i'll do anything in next days. Also rebuilt spare rear brake calipers so I can fix everything on the rear axle when I'll be doing the LSD and bearings rebuild. Drifting - best fun you can have in your car with your pants on! |
12-18-2005, 06:26 PM
Post: #295
Zax, get one of those cheap small electric fan heaters. They work pretty good if you place them near you and let them blow hot air at you. I use one in my shed and it heats up the shed relatively quickly..
12-18-2005, 07:04 PM
Post: #296
mux213 Wrote:Zax, get one of those cheap small electric fan heaters. They work pretty good if you place them near you and let them blow hot air at you. I use one in my shed and it heats up the shed relatively quickly..TE71Corolla used a single one to dry/heat his TE71 when he put it in primer. And it is indeed a very cheap option: you see those things for only 15 euros nowadays.
12-18-2005, 10:15 PM
Post: #297
ZaX Wrote:Ivan141 Wrote:How much did you pay for the SKF bearings?bearings for the rear axle and diff: ZaX, do I have to change all bearings, both for diff and axle? Which ones are for the diff only, the SKF or the Koyos? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
12-18-2005, 10:28 PM
Post: #298
nmwisima Wrote:ZaX Wrote:Ivan141 Wrote:How much did you pay for the SKF bearings?bearings for the rear axle and diff: Man, use your brain cells, not nmwisima's ass. 2 same bearings = one for each axle = koyo 2 different ones = for diff = skf :wink:
12-19-2005, 11:25 AM
Post: #299
Stupido ZaX, I got problem and cant see the pictures...
12-21-2005, 04:37 PM
Post: #300
OK, as I writen elsewhere I bought another hachi.
Description: blue metalic AE86 zenki GT, Bluetop 4A-GE MAP engine, 201k km on oddo, car is dented and scratched everywhere. There is no good panel on it. Doors, hood, hatch is rusty, sideskirts have big holes, all 4 fenders rusty, position lights broken, rear lamp broken, sunroof is bad, all seats have holes in them, there is no key (half of it is broken in lock) so no steering at the moment, windshield is broken.... I'll post the pics now, some of them from the morrning. Later I washed the car so it looks bit better now. Drifting - best fun you can have in your car with your pants on! |
| Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 19,481 |
| @dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 192,773 |
| Aram's 3SGE Beams Levin Coupe | robokill | 665 | 854,823 |
| Matt's "Drives as fast as it's Towed" 85 Levin Coupe | mad.matt | 38 | 48,429 |
04-07-2016 12:15 PM Last Post: mad.matt |
| DidiDex 1984 Levin coupe rebuild | DidiDex | 1 | 6,760 |
08-13-2015 03:22 PM Last Post: DidiDex |
![AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS [Image: AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS]](https://www.aeu86.org/sticker-banner-468.gif)
