Levin Coupe from Croatia - NOW SR86 with IRS
09-28-2004, 11:28 PM
Post: #31
My car was on alignement last time who know when, so i went today to a wheels alignement. Best spent 20€ on my car. Car now handles totaly different, handling is much improved. My current setings are:
Camber: -3.00° (used to be 1,6 i 0,7)
Caster: +3.00° (used to be 2,5)
Toe out: 0
[Image: AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS]
09-28-2004, 11:36 PM
Post: #32
cool man..... Cool
09-29-2004, 01:56 AM
Post: #33
ZaX Wrote:[quote="Ivan141"]Gheghe....the list never ends...
Wink
No need for negative RCA's since i have camber plates.
Remember....that mounting NCRCA´s will also extend your wheelbase quite significantly. I put the T3´s on mine and the difference is awesome. I will also be installing the camberplates when they arrive, just for the hell of it. Would be cool to get in excess of - 5degree camber Huh :wink:
09-29-2004, 09:42 AM
Post: #34
peter møller Wrote:Remember....that mounting NCRCA´s will also extend your wheelbase quite significantly. I put the T3´s on mine and the difference is awesome. I will also be installing the camberplates when they arrive, just for the hell of it. Would be cool to get in excess of - 5degree camber Huh :wink:
Altough -5° of camber looks cool, car is prone to much to undesteer.
I tried to drive my car with max camber on my camber plates and handling was bad. too much under.
As for extending the wheelbase, i think this pic explains pretty everything. Wink
10-01-2004, 07:21 PM
Post: #35
now thats one cool corolla you made all yourself zax!
-3° is a lot! cool man Smile
these camberplates look nice! where do get them from? i know some companies sell them but which is best (value for money). maybee you allready did some investigation Confused
10-04-2004, 02:29 PM
Post: #36
2 mo-racing: i orederd camber plates from T3 USA. 170$ + pp. They are best buy IMO.
new toys
Springs 6kg/mm
Before, with koni springs
After, with 6kg/mm springs = same height
new spring vs old spring
i instaled fog lights, need to connect them
also went to MOT station to check my air/fuel mixture (i was running bit lean, now i'm bit rich) and brakes balance.
10-04-2004, 03:13 PM
Post: #37
thank´s zax!
tell us how it is to ride 6kg/mm springs. musst be a little on the hard side Smile
for lambda 0.99. i think thats nearly ok. ideal would be 0.9 to 0.95 as far as i know. did you also measure the power output?
10-04-2004, 03:38 PM
Post: #38
hey Zax,
what are the specs of those koni springs btw?
10-06-2004, 02:17 PM
Post: #39
2 mux: sorry, don't know the koni spring specs
Ok guy, here are the updated specs of my drift AE86.
Specs:
Ride:
86 Toyota Corolla Levin Coupe AE86 white
VIN: JT1S0AE86 0012582
Owner
ZaX
Under the hood:
1991 4A-GE AE92-Kouki Red-Top engine,
16V 1595ccm, small port, no TVIS, 235ccm injectors,
NGK R plugs
BMC F1 air filter
Straight through exhaust
JUN type exhaust, made by Lastovcic
TRD oil cap
Increased holding capacity clutch kit
Mintex racing braking pads, 1144 compound
Mintex racing braking oil, 312°C boiling point
FINA First 0-40W 100% synthetic motor oil
Mobil Mobilube 1 SHC 75W-90, LSD oil
Shell 80W-90 gearbox oil
Stiff stuff: Front
Paradise racing coilover kit with 8kg/mm QA1 springs
Koni Sport yellow adjustables front with short stroke conversion (AE92)
T3 camber plates, runnin -3° camber and 3° of caster
Junbride Roll Center Adjusters 30mm
MOMO 20mm wheel spacer, hub centric
Rear
Koni Sport yellow adjustables in the rear
6kg/mm spring
Dual swaybar mod
Custom 25mm wheel spacer, hub centric
Rollers:
15" alu wheels, 4 x 114,3
TOYO Proxes T1-S 195/50/15
Tire Flys
TT +20mm wheel studs
Outside: Denso wipers
Inside:
Sparco Evo red seats, FIA homologated
Schroth 4 point harnes
Momo Corse red steering wheel
Nardi gear knob
Custom short shift kit
ICE
JVC CD-player
Further soon plans are: fog lights, side skirts from AE92, front lip, poliurethane PA6 bushings.
After that i plan to do paintjob (spring/summer 2005), roll cage, strut and chasis bracing.
My engine is completly stock, no plans yet.
What do you suggest me as a further upgrades of my car?
I'm on a limited budget so please keep that in mind. Smile
10-06-2004, 05:30 PM
Post: #40
Perhaps some sort of adjustable panhard rod and traction brackets to restore the geometry of the rear wheels. Not much more needed...
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 22,174 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 212,777 03-28-2018 12:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 926,038 09-03-2017 09:24 PM
  Matt's "Drives as fast as it's Towed" 85 Levin Coupe mad.matt 38 53,922 04-07-2016 12:15 PM
  DidiDex 1984 Levin coupe rebuild DidiDex 1 7,593 08-13-2015 03:22 PM
Last Post: DidiDex
