LHD W.G (West Germany) wires from dimmer & dash switch to headlight relays?
07-06-2014, 10:56 PM
(This post was last modified: 07-06-2014 10:58 PM by Rascal21.)
The latest oscillation problem can be attributed to low voltage in the engine room battery cable.
I fixed this by recharging the battery and soldering all the battery cable related cable shoes. I have working low beam, but high beam still only works with dimmer handle halfway pulled towards me (Before it clicks into position). So I took a gutted spare switch and tried that, same problem.. No idea whats going on here.. 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
07-07-2014, 09:16 AM
Try removing the headlight bulbs, then measure voltage at the power outputs to the bulbs in order to check your relay circuitry.
I get the feeling you are overthinking these electronics, there is very little in there that could cause any real oscillation. Mostly those kinds of effects can be attributed to low voltage on the relays, causing them to trip on and off fast. Also , if you're unsure about the switch, connect Red-Yellow switch wire to ground with a temporary toggle switch so you're sure the dimmer relay is being controlled properly. BTW, did you disconnect the indicator light circuit again? You say you had it working before you added that circuit, so it would be logical to undo that first to try to get back to a working system. FABRICA MI DIEM, PVNC! |
STL file for the early spec Levin headlight ball joint plastic clip | DaLanZhu | 2 | 1,300 |
04-26-2025 03:24 PM Last Post: DaLanZhu |
Ignition switch plug and wires | Blaze0010 | 3 | 1,560 |
Digital Dash | evfan42 | 190 | 290,955 |
05-03-2024 06:44 PM Last Post: banpei |
Fitting Air Con (No PS) to LHD AE86 | pack | 7 | 5,758 |
01-07-2024 11:36 AM Last Post: CCB |
Dash Waning Lights | pack | 7 | 5,714 |
10-06-2021 01:00 PM Last Post: pack |
