LHD AE86 headers and exhaust
03-19-2015, 12:18 PM
(03-18-2015 07:42 PM)Deuce Cam Wrote:  Hey guys how low is the martelius down pipe in relation to the frame rail under the car?
Also you what type of flanges do the they use at the cat connects? From the pics it almost looks lie the dp doesn't have a flange?
Ground clearance is a little worst than with the stock exhaust, but it's completely usable for the streets. I've not touched on anything (and where I live is full of speed bumps and ditches) except for my parking ramp which has an idiotic slope Banging head I have to try to raise the exhaust because it's a matter of 1 cm.
About the cat connects, my car was catless from the factory, so I don't know!
03-19-2015, 07:09 PM (This post was last modified: 03-19-2015 07:10 PM by Deuce Cam.)
^Thanks for the reply.
After reading Lt86's last post it dawned on me that some (if not all) of the EU models weren't originally equipped with cats. As a result it seems the Martelius unit doesn't have a provision for one.
03-19-2015, 08:50 PM
(03-19-2015 07:09 PM)Deuce Cam Wrote:  ^Thanks for the reply.
In Belgium we are lucky enough to be free of any regulations regarding emissions on oldtimer vehicles. I don't think there would be any reason for me to keep the cat Smile
03-20-2015, 05:52 PM
(03-19-2015 07:09 PM)Deuce Cam Wrote:  After reading Lt86's last post it dawned on me that some (if not all) of the EU models weren't originally equipped with cats. As a result it seems the Martelius unit doesn't have a provision for one.
From some preliminary researh I've done... France and Germany were the 2 Euro countries with some emissions requirements - they got cat equipped(9.4 to 1 compression). Other areas in Europe(and Singapore from my research) came without the cat(10 to 1 compression)
Dan -
03-20-2015, 07:07 PM
as far as I'm aware the CR difference was tied to MAP or AFM versions and not strictly to the CAT. My friends car was an 87 and had to have a CAT but no O2 sensor and no 10:1 CR as it was a AFM car. They did lot's of mixing with the emission parts all over Europe. in the Toyota Parts Catalog they differntiate between models for Switzerland/Sweden and Europe for the LHD european market.
03-20-2015, 11:19 PM
I know of Swiss and germany they have the cat and 4ageu
03-21-2015, 01:12 AM
(03-20-2015 07:07 PM)Bean Bandit Wrote:  as far as I'm aware the CR difference was tied to MAP or AFM versions and not strictly to the CAT.
not Europe... Japan had MAP and cat and 9.4 to 1
Dan -
03-21-2015, 01:14 AM
Didn't know that one.
03-21-2015, 11:05 PM
Indeed japan have map with cat & o2 sensor.
Euro with cat are MAF
Euro without cat were map & have no o2 sensor. For pollution, these versions have a green potentiometer
03-24-2015, 06:56 PM
(03-16-2015 09:48 PM)ditn Wrote:  If you can wait a month or so i will install a martelius street version full line but wiith a middle damper as well
Which you can ask them
Db goes from 100db to under 95db normally with no performance loss just 2kg more
Ditn do you already have the system or are you waiting for it to arrive?
  Fitting Air Con (No PS) to LHD AE86 pack 7 7,398 01-07-2024 11:36 AM
Last Post: CCB
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 25,757 05-01-2021 10:09 PM
  Headers recognition FanIsHere 2 4,771 11-23-2020 02:28 PM
Last Post: FanIsHere
  Exhaust has white smoke coming out and I dont know why... mister86 3 6,973 01-19-2020 12:06 AM
Last Post: Power_uP
  Most stock-resembling exhaust for the AE86? DaLanZhu 4 7,674 03-24-2019 04:10 PM
