Help with Wiring
04-02-2007, 03:48 AM
Help with Wiring
Hey,
Can any one help out with a wiring diagram of a AE86? Am putting mine onto Webbers but need to know what happens if I make the computer redundent. Does the computer run the dash? I want to retain the ability of putting the car back on injection if for some reason I decide to, so don't want to cut original loom. What are my options? Help would be wicked good!!!!! Cheers |
04-02-2007, 09:31 AM
Help with Wiring
We've already talked about using the original ECU for ignition when running carbs - check this thread;
http://www.aeu86.org/viewtopic/carbureti...4ag/t/4426 The only thing in the dash run by ECU is the 'check engine' -light, but it also controls the fuel pump so when using a mechanical distributor, you can't remove the ECU altogether unless you hardwire the pump to run. |
04-02-2007, 10:41 PM
Help with Wiring
Sorry guys, didn't find it.
Cheers, |
| Tail light wiring... | Mylesmck | 4 | 4,040 |
02-02-2024 12:36 PM Last Post: Mylesmck |
| Lambda sensor wiring | sam3007 | 10 | 9,969 |
| 4A-GE wiring engine to chassis connectors | Lykowsky | 4 | 10,606 |
06-20-2019 11:38 AM Last Post: Lykowsky |
| Some wiring help needed | DJexor | 5 | 8,790 |
| AE86 Headlight + wiper wiring (levin) | bozu | 11 | 23,157 |
09-19-2017 02:06 PM Last Post: banpei |
