02-20-2022, 02:01 PM
Post: #601
It is starting to look like a genuine car again! Thumbs up!
[Image: AEU86 AE86 - Ivan's coupe: bodywork is done]
03-02-2022, 12:51 PM
Post: #602
Does anyone here have experience with replacing the U-joints in the driveshaft?
2 out of the 3 u-joints in my driveshaft feel notchy, a clear indication that they are past it.
They are of a non-servicable type officially, so I cant easily find any replacement joints that should fit, although I suspect they do exist.
I read on Billzilla's old site that some common size may be fitted after some machining but I would prefer to avoid that.
A local driveshaft shop thinks they can get it done for me, but at €400 the cost is staggering.
03-02-2022, 07:29 PM
Post: #603
I had my driveshaft serviced last year.
Replaced all 3 U-joints with: GMB 016-GUT24
Parts cost was 79€ and the replacement work and balancing of driveshaft was 330€.
03-02-2022, 11:05 PM
Post: #604
Thanks.
I may just have to swallow the cost on this one. Proper u-joint installation would already be difficult enough, but getting these staked ones mounted correctly looks
a bit too difficult. Havent seen that part nr before, but the size looks familiar to others I've found (GMB 200-0024 / Febest ASM-CW5). Need to remeasure (cant find my calipers)
since I could swear the hole diameter was 24mm when I checked last time.
From what I've seen these solid ones are a better choice than those with grease fittings. In these small sizes those tend to snap when confronted with a bit of abuse.
The tricky bit with mounting new ones is getting them centered properly and making sure the axial endplay is within specification (<0.05mm). That last one is hard to do in a shed.
Rebalancing should not be necessary but it is probably not the biggest part of the cost.
03-05-2022, 12:46 PM
Post: #605
Progress report:
-Bent up new cunifer brake lines for the rear axle. Not an easy task, but the result looks like it will work:
Next to crusty old suspension for contrast:
What's this? No more rotisserie, thats what.
The eagle has landed:
Todo items on my mind these days:
-Refurb driveshaft. I ordered 3 new u-joints for about €30. I'm going to attempt it myself. As long as I dont screw up the yokes I can still dump it at a specialist store if DIY doesnt go well.
-Prepare reconditioned rear brake anchor plates and hardware for mounting to axle. (zinc-plate the bolts/nuts, clean up my 'new' calipers.
-Buy some stuff for finishing off the rear axle (solid spacer kit, gasket kit, axle end plates).
When I have a working parking brake again the next priority is getting the shell reunited with the doors and trunk/bonnet so we can start 'mudding' the heck out of it.
03-06-2022, 09:55 PM
Post: #606
That's some great progress! Finally she's on her own feet again! Thumbs up!
So which car is next in line for the rotisserie?
03-07-2022, 04:03 PM
Post: #607
Nice! Keep up te good work and the momentum. She’s almost ready for MOT!
AE86 Levin
03-08-2022, 09:44 AM
Post: #608
Nice work!
03-21-2022, 10:09 AM
Post: #609
good work!
Gtsi-R
"Trust me, I was an engineer"
05-04-2022, 12:58 PM
Post: #610
I'm following this with much interest.... great work Ivan
  My little (not really...) project - Soon to be all done?!? Jan Pedersen 516 698,055 06-27-2013 12:28 PM
Last Post: T_AE86
  Another SR20DET conversion allmost done :) peter møller 7 18,209 05-04-2011 01:16 PM
Last Post: worholm
  Yay! Its now done and on the road! Black Betty 24 28,740 01-20-2006 08:12 PM
Last Post: Black Betty
  Bodywork in 3 steps max_ae86 67 76,625 01-03-2006 02:34 PM
Last Post: Apolan
User(s) browsing this thread: 17 Guest(s)
