Injector size advice on 7age
01-18-2007, 06:33 AM
I´m about to put my 7age together, finally.
I need advice on which injectors to use.
Short resume...
It will be 1.8liter, redtop pistons, Shrick 258cams.
Will it be advisable to use a fuel regulator?
My evil Red/Black Panda
My current JDM AE86 project
01-18-2007, 10:42 AM
Ideally, you should run the injectors on their perscribed fuel-pressure, or a tiny bit above.
If you give me you est.hp level its peanuts to calculate injector.flowrate tons of calculators on the net.
Most important thing to keep an eye on is that the engine management can handle the new injectors.
01-18-2007, 04:48 PM
Hey nohachi....
Please make the calculation for me...estimated HP is close to 165-170!
Thanks
01-18-2007, 05:11 PM
I come up with about 311cc/min for 170hp. Thats calculating everything to its maximum. More then likely the 295cc/min injectors from 20V engines will be more then enough to sustain your desired horsepower levels.
Do make sure that fuelpressure is within spec at a minimum of 35psi.
Red/blue top injectors will not work properly. You will not get a clean injection of fuel during each cycle. The resulting lean condition in individual cylinders will be hard to detect, but will slowly chew away at an already weak engine design.
01-18-2007, 05:45 PM
Peter,,
are you going to use itb´s?
or the regular manifold
/skassa
"""www.turbotoys.dk"""
01-19-2007, 01:26 AM
NoHachi Wrote:I come up with about 311cc/min for 170hp. Thats calculating everything to its maximum. More then likely the 295cc/min injectors from 20V engines will be more then enough to sustain your desired horsepower levels.
Thanks for the info man.....you think AGZE injectors will do the trick? Cant remember their cc/min capacity Thumbs up!
01-19-2007, 01:28 AM
Denmark Wrote:Peter,,
/skassa
Hi Skassa....
To begin with I will use a redtop manifold which has been modified to fit the AE86.
Allthough i have a complete set of 20v ITB´s and adapter in the shed. This will have to wait until i know if "turbomotor.dk" can fix the ECU to run them.
I simply dont have the money to run standalone at the moment.
01-19-2007, 11:16 AM
Hi Peter,
GZE injectors are 370cc/min, so they flow more then enough.
01-19-2007, 06:13 PM
Hi.
I can´t imagine that it will run well,with gze injector without changing the ecu,
I belive it will run fine with oe injectors,with just raised pressure,that will also not cost anything(just cruch the oe fpr in a "skruestik",
That will do the trick.
I just had my blacktop on dyno,and that made 161hp@7930rpm, and 165nm@6050rpm,
The old engine with schrick 256, janspeed manifold and 2" exhaurst ,made 134hp@7150rpm -142nm@4200rpm,
So there is "some" more power in the blacktop Smile
/Skassa
01-19-2007, 08:10 PM
Denmark Wrote:Hi.
/Skassa
Thanks for the advice, but i will be running an aftermarket regulator (Sard i think)
Can you remember the flow rates of the other injectors?
I allways seem to forget Banging head
  7AGE Build apardal 5 5,509 08-02-2024 12:11 PM
Last Post: apardal
  Shim size for AM cams kazi 4 8,158 12-18-2017 05:34 PM
  Brake advice - master cylinder mannix20vt 12 20,573 08-21-2017 03:21 PM
Last Post: Project D
Wink Hub size kazi 5 13,165 06-09-2017 10:06 PM
Last Post: kazi
  timingbelt 7age 20V!! slowboy2 3 10,010 06-21-2016 09:41 AM
Last Post: ditn
