Ignition wiring
04-14-2007, 11:47 AM
Ignition wiring
I have done a search on this but cannot find what I need to know, basically the car needs to have a masterswitch fitted that will not only disconnect the battery feed but will also stop the engine, I have the switch fitted but I don't know which wire from the ignition to feed to the switch to stop the engine.
Just cutting the battery feed will probably destroy the alternator and will not cut the engine.
Thanks for any help
04-14-2007, 12:57 PM
Ignition wiring
I think the best way to stop the engine is to make a switch in the EFI wiring. Two possible places to do it its under the fuse box (on the efi fuse) or near the ecu. Cutting efi wiring cuts the connection to injectors, so no fuel feed will be created. I think this would cut fuel pump too (cant remember the diagram to be sure).
[Image: AEU86 AE86 - Ignition wiring]
Cump“s
Filipe Oliveira
04-15-2007, 11:06 PM
Ignition wiring
Would this help? Dumb question
http://www.aeu86.org/mirror/hachilife_ma...odyelec_09
  Ignition switch plug and wires Blaze0010 3 4,360 11-25-2024 12:29 PM
Last Post: Blaze0010
  Tail light wiring... Mylesmck 4 3,989 02-02-2024 12:36 PM
Last Post: Mylesmck
  Lambda sensor wiring sam3007 10 9,859 05-23-2022 10:00 PM
Last Post: The Doctor
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 18,930 07-18-2019 03:52 PM
  4A-GE wiring engine to chassis connectors Lykowsky 4 10,561 06-20-2019 11:38 AM
Last Post: Lykowsky
