Ignition wiring
04-14-2007, 11:47 AM
Ignition wiring
I have done a search on this but cannot find what I need to know, basically the car needs to have a masterswitch fitted that will not only disconnect the battery feed but will also stop the engine, I have the switch fitted but I don't know which wire from the ignition to feed to the switch to stop the engine.
Just cutting the battery feed will probably destroy the alternator and will not cut the engine. Thanks for any help An analogue brain in a digital World |
04-14-2007, 12:57 PM
Ignition wiring
I think the best way to stop the engine is to make a switch in the EFI wiring. Two possible places to do it its under the fuse box (on the efi fuse) or near the ecu. Cutting efi wiring cuts the connection to injectors, so no fuel feed will be created. I think this would cut fuel pump too (cant remember the diagram to be sure).
![]() Cump“s Filipe Oliveira |
04-15-2007, 11:06 PM
Ignition wiring
| Ignition switch plug and wires | Blaze0010 | 3 | 4,139 |
| Tail light wiring... | Mylesmck | 4 | 3,881 |
02-02-2024 12:36 PM Last Post: Mylesmck |
| Lambda sensor wiring | sam3007 | 10 | 9,608 |
| 20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 18,722 |
| 4A-GE wiring engine to chassis connectors | Lykowsky | 4 | 10,441 |
06-20-2019 11:38 AM Last Post: Lykowsky |
![AEU86 AE86 - Ignition wiring [Image: AEU86 AE86 - Ignition wiring]](http://lipinhu.no.sapo.pt/sbanner.jpg)
![AEU86 AE86 - Ignition wiring [Image: AEU86 AE86 - Ignition wiring]](https://www.aeu86.org/sticker-banner-468.gif)
