Ignition problem:connecting T and E1 terminals->no effect
12-02-2008, 01:37 AM
To set the timing, before you short the termials, you must be certain :
1. Engine idles around 850 rpm. 2. AFM idle switch is closed. 3. All accessories (lights, A/C, heater, demister etc) are OFF. Then, when you short the terminals, the rpm should drop as the ECU removes some timing. Even so, without shorting the terminals, 16-17 deg BTDC should be about right. Cheers... jondee86 |
| Messages In This Thread |
Ignition problem:connecting T and E1 terminals->no effect - spinny - 12-01-2008, 10:30 PM
[] - jondee86 - 12-02-2008 01:37 AM
| Ignition switch plug and wires | Blaze0010 | 3 | 2,669 |
| 20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 16,948 |
| extracted freedom ecu 16v ignition map | ditn | 7 | 11,497 |
| 4AGE 20v Ignition Lead Length | mad.matt | 3 | 8,194 |
10-01-2014 03:43 PM Last Post: mad.matt |
| [Tutorial Video] Setting 4A-GE Ignition Timing | Homem Bomba | 0 | 6,844 |
04-21-2014 02:41 PM Last Post: Homem Bomba |
