IAC valve
05-28-2010, 09:45 PM
IAC valve
i have i high idle on my engine and I'm talking about 1800-2000 rpm, and I'm sure that the Idle Air Control valve doesn't work, is there any way that this can be blocked so the engine can come back to a normal idle ...? and if so how can i fix this problem ?
'85 Corolla Sprinter Trueno GT-APEX |
05-28-2010, 10:31 PM
IAC valve
can't you try to clean it ?
05-28-2010, 10:49 PM
IAC valve
How do i clean it. I just have to take it out and clean it but is there a special fluid to clean this ..?
05-28-2010, 11:47 PM
IAC valve
CoolinAE86 Wrote:i have i high idle on my engine and I'm talking about 1800-2000 rpm, and I'm sure that the Idle Air Control valve doesn't work, is there any way that this can be blocked so the engine can come back to a normal idle ...? and if so how can i fix this problem ? Go inside the throttle body and find the idle air port. Its just in front of the throttle butterfly at about 5 o'clock. Block the hole temporarily with a rubber plug or even your finger (for testing). If the idle drops by 1000 rpm, then your thermostatic idle-up valve is stuck wide open (if the idle only drops by 100 rpm, the problem is elsewhere). You can block it off permanently and put up with poor cold starting and a rising idle, or fix/replace the valve. Cheers... jondee86 |
05-30-2010, 08:22 PM
IAC valve
jondee86 Wrote:CoolinAE86 Wrote:i have i high idle on my engine and I'm talking about 1800-2000 rpm, and I'm sure that the Idle Air Control valve doesn't work, is there any way that this can be blocked so the engine can come back to a normal idle ...? and if so how can i fix this problem ? Thanks man the valve was stucked so i will try to block it up permanently thanks man '85 Corolla Sprinter Trueno GT-APEX |
| 4A-GE valve shim disintegrated | DaLanZhu | 2 | 3,183 |
04-30-2025 12:54 PM Last Post: DaLanZhu |
| 4AGE Valve Buckets Scored | Steller Engineering | 2 | 3,113 |
| 20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 4,270 |
| HKS valve springs | totta Crolla | 3 | 4,875 |
| Valve clearance | leon205gti | 7 | 12,215 |
11-25-2016 03:24 AM Last Post: oldeskewltoy |
