How to set ignition timing???
06-24-2008, 09:24 AM
So if the timing is supposed to be set at 5 degrees, I take some chalk and put a mark on the belt at five degrees while the car's off? The start the car and see if the light flashes on the mark? How far should I hold the timing light from the belt? And does this sound right?
Jason |
06-24-2008, 10:09 AM
Quote:To set the timing you need to get hold of a timing light and a short The 10 deg base timing applies to 16V 4AGE with EFI. The timing marks are down by the crankshaft pulley, so you need to get the light shining down on the pulley. The mark on the pulley will appear to be stationary under the strobe, and you see where it lines up with the scale on the timing cover. Rotate the distributor until the notch on the pulley is opposite the 10 deg marking. Cheers... jondee86 |
06-28-2008, 11:16 PM
Very important to bypass the plug on the firewall with a jumper. This affects it greatly!
06-30-2008, 02:31 AM
anyone know where's the vacuum advance hose on a 4ac?
| Ignition switch plug and wires | Blaze0010 | 3 | 3,287 |
| 20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 17,793 |
| 4agze timing | leon205gti | 11 | 18,151 |
04-07-2017 03:10 AM Last Post: jondee86 |
| Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 7,136 |
| extracted freedom ecu 16v ignition map | ditn | 7 | 12,166 |
