How to remove the water pump?
02-20-2007, 08:36 PM
Hi,
I'm disassembling my 4A-GE but i'm with some troubles to remove the water pump because there's a bolt near the timming belt that's a bit difficult to remove. It isn't properly easy to access it. It is necessary any SST? Any suggestions how to remove that bolt? Thanks |
02-20-2007, 08:46 PM
i didn't use any special things. I only removed the front caps of the timingbelt.
02-20-2007, 08:49 PM
Ok, the problem is that i don't have a socket able to pass between the bolt and the water pump pulley.
Did you removed the water pump pulley? |
02-20-2007, 09:11 PM
yes i did. there are 4 nuts you have to loosen.
| Passenger roof grab handle - how to remove ? | ondafly | 3 | 1,280 |
02-19-2026 07:20 PM Last Post: ondafly |
| 20v BT - which oil pump? | Mylesmck | 4 | 5,839 |
| Fuel pump issue | DJexor | 11 | 11,198 |
| Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 11,611 |
12-06-2017 06:48 PM Last Post: Bean |
| fuel line hose from the pump | Wikizz | 4 | 8,398 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
