How to remove the water pump?
02-20-2007, 08:36 PM
Hi,
I'm disassembling my 4A-GE but i'm with some troubles to remove the water pump because there's a bolt near the timming belt that's a bit difficult to remove.
It isn't properly easy to access it.
It is necessary any SST? Any suggestions how to remove that bolt?
Thanks
02-20-2007, 08:46 PM
i didn't use any special things. I only removed the front caps of the timingbelt.
[Image: AEU86 AE86 - How to remove the water pump?]
02-20-2007, 08:49 PM
Ok, the problem is that i don't have a socket able to pass between the bolt and the water pump pulley.
Did you removed the water pump pulley?
02-20-2007, 09:11 PM
yes i did. there are 4 nuts you have to loosen.
  Passenger roof grab handle - how to remove ? ondafly 3 1,224 02-19-2026 07:20 PM
Last Post: ondafly
  20v BT - which oil pump? Mylesmck 4 5,769 06-21-2022 04:51 PM
Last Post: pack
  Fuel pump issue DJexor 11 11,024 04-29-2022 05:45 AM
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 11,499 12-06-2017 06:48 PM
  fuel line hose from the pump Wikizz 4 8,358 10-16-2017 07:11 PM
Last Post: jdm86gtz
