High engine oil temps - oil cooler discussion
06-02-2008, 03:37 PM
speed-inc Wrote: Great, thanks. What is that metal thingy connecting the pipes on this picture? Did you connected the oil coolers 'serial' or 'paralell'? 1987 Toyota Corolla GT coupe - for holidays oversteer 2005 Toyota Corolla - for daily understeer |
06-02-2008, 03:55 PM
That is the thermostat. Opens at 70°C I think
They're connected serial. Speed Industries Hurdnerwaeldlistr. 73 8808 Pfaeffikon Switzerland e-mail: [email protected] phone: +4155 420 15 69 page: http://www.speed-industries.ch MSN: [email protected] We have all the parts your Hachi needs |
06-02-2008, 04:04 PM
So if your oil gets hot and the normal oil cooler is not sufficient annymore.. the oil will also run trough the seccond cooler If I am correct..
PS if you look for a Good origional oilcooler.. I have one extra in stock.. Bought mysevle a large Mocal oil cooler! Cheers Roel Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
06-03-2008, 06:02 AM
Shroud the oil cooler using plastic / aluminium / carbon fibre. It will make a lot of difference to how it performs and will mean more track time.
Also useful to set up a water jet system - can use the screen washer tank as reservoir. VISIT OUR NEW WEBSITES!!!! A Tuner's Paradise Automotive Art On Film Dedication To Automotive Perfection Japan Office Tel - (Calls charged at UK National Rate): 0207-193-3979. Mobile (Japan): +81- (0) 90-4133-3825 Fax (Japan): +81-(0) 47-307-4678 |
06-03-2008, 07:25 AM
FC3S oil cooler 5 years now and 2 motors ago still running strong keeps my oil 90C to 100C all day 9,200rpm. people dont know that FC3S oil cooler has a build in thermostat.
06-03-2008, 08:36 AM
This sounds interesting. Did you simply connected the pipes to the engine block like it's in stock?
06-03-2008, 08:57 AM
SutteR Wrote:This sounds interesting. Did you simply connected the pipes to the engine block like it's in stock? yes, just remember to put it upside down, the thermostat plug facing up so you can unscrew the plug and drain it every oil change. |
06-03-2008, 09:01 AM
4agze Wrote:SutteR Wrote:This sounds interesting. Did you simply connected the pipes to the engine block like it's in stock? How much oil fits in this cooler BTW? I mean there is a need of putting extra amount of oil in the engine when using this. 1987 Toyota Corolla GT coupe - for holidays oversteer 2005 Toyota Corolla - for daily understeer |
06-03-2008, 09:28 AM
SutteR Wrote:[quote="4agze"][quote="SutteR"] well what i do every oilchange is put my regular amount by the dip stick, then run the motor for 1 min then check the dip stick, add oil. I cant say how much cuz i buy my oil per big gallon size. |
06-03-2008, 09:36 AM
As far as I know there is a pressure operated valve in stock. If you use the stock lines with the FC3S oil cooler won't it operate only on high revs because of this pressure valve?
Question is if it can be avooided to run the oil through this pressure valve. 1987 Toyota Corolla GT coupe - for holidays oversteer 2005 Toyota Corolla - for daily understeer |
| Blacktop 20V high idle | Bravothreezero | 2 | 326 |
08-10-2026 04:58 PM Last Post: ondafly |
| High-beam warning lamp | Mylesmck | 4 | 4,397 |
07-21-2023 07:44 AM Last Post: banpei |
| Mocal oil cooler & sandwitch plate ordered | Gtsi-R | 48 | 72,253 |
| Engine stress at high speeds | gh0st | 6 | 5,928 |
08-30-2022 07:11 PM Last Post: Power_uP |
| Oil cooler | totta Crolla | 0 | 2,893 |
![AEU86 AE86 - High engine oil temps - oil...discussion [Image: AEU86 AE86 - High engine oil temps - oil...discussion]](http://i65.photobucket.com/albums/h205/driftomachine/IMG_3425.jpg)
![AEU86 AE86 - High engine oil temps - oil...discussion [Image: AEU86 AE86 - High engine oil temps - oil...discussion]](http://i223.photobucket.com/albums/dd98/narcisomelvin/AE86/Oct140601.jpg)
