High engine oil temps - oil cooler discussion
06-02-2008, 03:37 PM
speed-inc Wrote:[Image: AEU86 AE86 - High engine oil temps - oil...discussion]
Great, thanks. What is that metal thingy connecting the pipes on this picture? Did you connected the oil coolers 'serial' or 'paralell'?
1987 Toyota Corolla GT coupe - for holidays oversteer
2005 Toyota Corolla - for daily understeer
06-02-2008, 03:55 PM
That is the thermostat. Opens at 70°C I think
They're connected serial.
Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: [email protected]
phone: +4155 420 15 69
page: http://www.speed-industries.ch
MSN: [email protected]
We have all the parts your Hachi needs
06-02-2008, 04:04 PM
So if your oil gets hot and the normal oil cooler is not sufficient annymore.. the oil will also run trough the seccond cooler If I am correct..
PS if you look for a Good origional oilcooler.. I have one extra in stock..
Bought mysevle a large Mocal oil cooler!
Cheers Roel
Gtsi-R
"Trust me, I was an engineer"
06-03-2008, 06:02 AM
Shroud the oil cooler using plastic / aluminium / carbon fibre. It will make a lot of difference to how it performs and will mean more track time.
Also useful to set up a water jet system - can use the screen washer tank as reservoir.
VISIT OUR NEW WEBSITES!!!!
A Tuner's Paradise
Automotive Art On Film
06-03-2008, 07:25 AM
FC3S oil cooler 5 years now and 2 motors ago still running strong keeps my oil 90C to 100C all day 9,200rpm. people dont know that FC3S oil cooler has a build in thermostat.
06-03-2008, 08:36 AM
This sounds interesting. Did you simply connected the pipes to the engine block like it's in stock?
06-03-2008, 08:57 AM
SutteR Wrote:This sounds interesting. Did you simply connected the pipes to the engine block like it's in stock?
yes, just remember to put it upside down, the thermostat plug facing up so you can unscrew the plug and drain it every oil change.
06-03-2008, 09:01 AM
yes, just remember to put it upside down, the thermostat plug facing down so you can unscrew the plug and drain it every oil change.
How much oil fits in this cooler BTW? I mean there is a need of putting extra amount of oil in the engine when using this.
06-03-2008, 09:28 AM
SutteR Wrote:[quote="4agze"][quote="SutteR"]
well what i do every oilchange is put my regular amount by the dip stick, then run the motor for 1 min then check the dip stick, add oil. I cant say how much cuz i buy my oil per big gallon size.
06-03-2008, 09:36 AM
As far as I know there is a pressure operated valve in stock. If you use the stock lines with the FC3S oil cooler won't it operate only on high revs because of this pressure valve?
Question is if it can be avooided to run the oil through this pressure valve.
  High-beam warning lamp Mylesmck 4 3,247 07-21-2023 07:44 AM
  Mocal oil cooler & sandwitch plate ordered Gtsi-R 48 66,242 11-18-2022 02:19 PM
Last Post: FanIsHere
  Engine stress at high speeds gh0st 6 4,676 08-30-2022 07:11 PM
Last Post: Power_uP
  Oil cooler totta Crolla 0 2,330 07-25-2021 03:25 PM
Last Post: totta Crolla
  4AGE 16V engine overheat when at high speed chenfon 32 32,184 12-31-2020 06:39 AM
Last Post: chenfon
