Help w flywheel problem.
07-15-2008, 08:54 PM
I have fixed my engine now.. all works good.. but some things worries me.
I have fitted the early ae92 engine (bigport 4age) in my car. And now it feels like the clutch doesnt opens so much as before. Kind of hard to explain. When i puch down the clutch pedal it feels like it only engages a little.. cud this be a different size of flywheel issue? Thanks Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
07-16-2008, 10:13 AM
Should be the same flywheel.. you sure the clutch is working ok?
07-16-2008, 11:33 AM
its the same clutch i had in my 4a-c engine. that clutch i bought to fit the ae92 early engine
07-17-2008, 01:37 AM
Try to use the AE86 one. It has a lower moment of enertia which means its should spin faster.
| light weight Flywheel | filh | 9 | 10,606 |
02-05-2018 05:20 PM Last Post: filh |
| crank 6 bolt flywheel | DJexor | 5 | 10,682 |
12-05-2016 08:21 AM Last Post: d3nso |
| Flywheel fitting | totta Crolla | 11 | 16,647 |
11-24-2013 05:31 PM Last Post: Apsogos |
| 4agZe problem solved - 99% IC problem | Okami | 41 | 48,013 |
| Idle problem!!! HELP!! | panda_tureno86 | 6 | 8,602 |
02-28-2012 07:47 PM Last Post: panda_tureno86 |
