Heater Light ?
12-28-2004, 01:22 AM
Heater Light ?
My heater console does not light up. I had the same problem with the light surrounding the lighter and have found the blown bulb for this.
Does anyone know where the bulb for the heater console is ?
The rest of the dashboard lights up (speedo, revs etc etc)
12-28-2004, 01:34 AM
Heater Light ?
Ain't it somewhere in the footwell? If you don't know the position of the fuse just check all of them.
12-28-2004, 01:36 AM
Heater Light ?
the fuses are fine, i think its the actual bulb. Does it even have a bulb ?
12-28-2004, 01:37 AM
Heater Light ?
Its a light system like your dashboard (speedo meter etc) you will have to remove the console and remove the panel
12-28-2004, 02:22 AM
Heater Light ?
I have removed that panel once, the lighting should be integrated into the heater controls..
I shorted the wires of the heater lighting once, trying to tap a lighting source for my oil temp gauge, and it wouldnt light up for a few weeks.
Strangely enough it started working again after a while...You need to take of quite a bit of dashboard to be able to get to that panel though, I would advise you to remember the assembly order very well since it is sometimes slightly confusing.
  AE86 Heater Control Light Super86 8 13,450 07-20-2016 07:22 AM
Last Post: Super86
  Carina TA62 / TA60 heater blower stopped working Bushido 9 15,869 11-14-2014 12:57 AM
Last Post: Bushido
  Heater issue Jezza_hr 9 17,770 10-02-2014 07:51 PM
Last Post: Jezza_hr
  Heater blower removal phill 92 2 5,974 12-13-2012 10:55 AM
Last Post: allencr
  Leaky heater control valve? phill 92 1 4,844 03-13-2012 05:40 PM
Last Post: phill 92
