HELP!!! hard time starting
03-29-2012, 08:59 PM
Check/refresh the grounding of the igniter to the chassis. It grounds through
the outer casing, so it needs to be bolted down with a good contact to the
chassis.
Check the wires that conect to the distributor at the point where they pass
from outside to inside. Due to constant flexing the wires can break or rub
through the insulation. Look inside and outside the distributor for any signs
of "soft" wires (broken inside the insulation), exposed wires, bad
connections.
Check for damage inside the distributor cap. Clean all the metal surfaces
and make sure the outer edge of the rotor is square and not covered in
oxidation. Make sure the carbon button is still there.
Cheers... jondee86
Messages In This Thread
HELP!!! hard time starting - drift - 03-17-2012, 04:33 AM
[] - fax0815 - 03-17-2012, 09:18 PM
[] - drift - 03-18-2012, 07:16 AM
[] - fax0815 - 03-18-2012, 02:22 PM
[] - drift - 03-18-2012, 03:33 PM
[] - Ivan141 - 03-18-2012, 04:01 PM
[] - drift - 03-18-2012, 05:31 PM
[] - Ivan141 - 03-18-2012, 10:30 PM
[] - fax0815 - 03-19-2012, 12:59 AM
[] - drift - 03-19-2012, 01:28 AM
[] - drift - 03-20-2012, 07:58 PM
[] - Ivan141 - 03-20-2012, 11:08 PM
[] - jondee86 - 03-20-2012, 11:32 PM
[] - drift - 03-21-2012, 01:21 AM
[] - fax0815 - 03-21-2012, 01:49 AM
[] - drift - 03-21-2012, 02:38 AM
[] - fax0815 - 03-21-2012, 03:55 AM
[] - drift - 03-21-2012, 07:06 AM
[] - drift - 03-21-2012, 10:06 PM
[] - fax0815 - 03-21-2012, 10:38 PM
[] - drift - 03-22-2012, 01:32 AM
[] - drift - 03-22-2012, 02:56 AM
[] - drift - 03-23-2012, 10:10 AM
[] - fax0815 - 03-24-2012, 02:01 PM
[] - drift - 03-29-2012, 01:31 AM
[] - jondee86 - 03-29-2012, 04:23 AM
[] - drift - 03-29-2012, 05:05 AM
[] - drift - 03-29-2012, 08:13 PM
[] - jondee86 - 03-29-2012 08:59 PM
[] - drift - 03-29-2012, 09:12 PM
[] - fax0815 - 03-30-2012, 05:02 AM
[] - drift - 03-30-2012, 06:13 AM
[] - fax0815 - 03-30-2012, 11:51 PM
[] - drift - 04-11-2012, 09:01 AM
[] - fax0815 - 04-18-2012, 10:56 PM
[] - drift - 04-23-2012, 01:40 AM
  Coil charge time totta Crolla 0 945 01-23-2026 07:27 AM
Last Post: totta Crolla
  lntermittent starting totta Crolla 6 7,040 08-31-2021 06:21 PM
  Starting problems 4-AGE kouki Hanzo 3 5,201 08-31-2021 06:20 PM
  Hard start issue kazi 5 9,653 05-23-2017 11:31 PM
Last Post: kazi
  JDM trueno not starting. need help! kazi 8 13,005 03-12-2017 05:05 PM
Last Post: kazi
